New AutoCAD drawing, and PDF, for lowering brackets - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 11-21-2007, 01:10 PM Thread Starter
mstewflyr's Avatar
Thanks to BMan for the lowering brackets, he originally posted them in PDF format, and as soon as he could he would post AutoCAD files, I had a friend of mine @ work create these files, from BMan's drwaings, here they are for all who are interested.
"2001 Vulcan 750"
Memphis Shades,
Mustang Seats
13200 Miles @ purchase Feb. 07
20000 Miles, Oct. 07
mstewflyr is offline
post #2 of 7 (permalink) Old 11-22-2007, 02:26 AM
BMan23777's Avatar
Your welcome for the original drawings but Chiron gets credit for getting me to send the drawings to him and his father and they did the rest.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #3 of 7 (permalink) Old 11-22-2007, 02:30 PM
Thank you!!!!
googy00 is offline
post #4 of 7 (permalink) Old 11-22-2007, 03:44 PM
BMan23777's Avatar
Just make sure you use at least 1/4" plate when you make them.First set wasn't and they bent on me.
Brian Manchester
'89 "GRIMM"
04 durango AWD
post #5 of 7 (permalink) Old 03-26-2008, 07:54 AM
what about the lenght of the rear axle?... it's enough to put the brackets with the standard axle?
Thank you.
yknot is offline
post #6 of 7 (permalink) Old 03-26-2008, 02:02 PM
BMan23777's Avatar
On the swingarm side you need to grind down the shoulder around the axle shaft hole in order for the bracket to sit straight.this is enough so the stock axle can be used.
Brian Manchester
'89 "GRIMM"
04 durango AWD
post #7 of 7 (permalink) Old 03-27-2008, 05:25 PM
ok, thanks
yknot is offline
