Myth or Fact? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 11-11-2007, 10:09 AM Thread Starter
dirtrack650's Avatar
Myth or Fact?
I've been talking with several of the local wrenches about the carbs, shave, vac lines, and goat. Here's some items I picked up from them:
  • when removing the goat, replace it with a x-over tube.
  • when removing the vacuum valve/tubes if needed couple vac lines together if needed to maintain vac hose balance.
  • It's more difficult to maintain carb sync if CV carbs don't share the same air box. The shave with filter pods is more cosmetic than functional.
I shaved - for looks - but reinstalled my drilled goat after R/R relocate.
dirtrack650 is offline
post #2 of 14 (permalink) Old 11-11-2007, 10:59 AM
I tried to use the car air filters on mine but they for some reason did not flow enough air. I do not feel that the pods are as good a filter, but the bike runs a whole lot better with them than the others. And it looks a whole lot better with the pods.
post #3 of 14 (permalink) Old 11-11-2007, 12:36 PM
"when removing the goat, replace it with a x-over tube."
TRUE. The "belly" is as Kaw calls it a "power chamber". It provides better low end grunt. Think of the system a being like a 2 into 1 setup. It just happens to be more of a 2 into 1 into 2 again thing...
"when removing the vacuum valve/tubes if needed couple vac lines together if needed to maintain vac hose balance."
TRUE. Well, for the most part. The vacuum lines off the carb going to the right airbox are already joined. Any time you connect them they should meet at a shared chamber of some kind.
"It's more difficult to maintain carb sync if CV carbs don't share the same air box. The shave with filter pods is more cosmetic than functional."
Kinda True. The carbs need to have the same "restrictions", but generaly filters like the K+N pods are so unrestrictive that you'd have to be feeding a mighty big engine to over come their limits. This was mostly a problem with old inline fours that had 4 pods across . The outer pods tended to collect dirt faster , to the point that if not cleaned on a periodic bassis they would effect the balance.
And the fact that CV carbs are more dependent on engine vacuum, (engine side of the carb) for metering purposes, air restriction would have to be highly diffrent.
post #4 of 14 (permalink) Old 11-12-2007, 11:09 AM Thread Starter
Good post KM.
One of the people I spoke with on this thread was a crotch rocket builder. His favorites were the FZ Yamaha's with the Pop's Yoshi kits - 4 cyl with 4 into 1. The instructions for the kit was to leave the stock air box in place but drill several 1/2 to 3/4 inch holes in the rear of the box and use a high flo air filter.
I thought this practice was 'old news' until my brother had his Triumph (900 triple) serviced at the dealer. They asked him if he wanted a performance boost free of charge for being a Triumph owner - and they did the same thing: drilled the air box and tuned the carbs. Now I can't keep up with him - it made a big difference on his bike.
What I wonder about when using pods is a vacuum effect that might change our carbs performance. When air is passing by our shaved intakes, is there a vacuum created by the passing wind that effects the tuning and balance vs. the stock air box? The pressure difference at the carb's intake pointing 180 degrees would be different depending on how fast the bike is going.
Just thinking out loud...
post #5 of 14 (permalink) Old 11-12-2007, 12:34 PM
Crobins365's Avatar
Theoretically, yes. The air box is there to provide a still source of air for the carbs. Once it's moving, you've lowered the external air pressure (inversely proportional to speed), and that should affect tuning.
I'm still trying to think about the holes in the airbox and how that boosts performance...(theoretically). Anyone?
C
Crobins365 is offline
post #6 of 14 (permalink) Old 11-12-2007, 12:48 PM
The only problem that I noticed when doing the ear shave was with the carb vent hose that was pluged to the right ear. Now when riding in strong wind the air tends to go into that hose and push the carb diaphram enough that it tends to slow the bike down and then it speeds up when past the gust of wind. It is not the push on the shield that I refur to.
With the holes in the air box, would one get unfiltered air into the carbs and engine??
post #7 of 14 (permalink) Old 11-12-2007, 04:16 PM
Find you a small in line fuel filter for 1/4 inch fuel line. Most likely in a lawnmower shop or even at Wal Mart. Plug it in the line and hang it high next to the frame under the tank.
Also the holes in the air box have to be before the filter so you don't get unfiltered air in the engine. This allows more air to the filters.
Don't forget when you marble and shave the ears you can use the right side hose from the reed valve to raise the crankcase vent to just below the frame under the tank.
thediode is offline
post #8 of 14 (permalink) Old 11-12-2007, 04:47 PM
They could, but I doubt they do. The "pod" filters don't really stick out into the airstream like the stock ears. And they pull air in from a 360 degree area around the filter. Both K+N's and Uni filters do this and although differ in design, are about the same size.
The vacuum line that goes into the right stock air box is critical. The post about using a filter and tucking it up under the gas tank is 100 % right-on, as any change in air pressure around this line will effect the carbs performance.
post #9 of 14 (permalink) Old 11-13-2007, 01:02 AM
I have the small filter, but I probably don't have it up hidden enough from the air flow.
I still don't understand where they drill the holes in the air box. All the air in the box is filterd air, any hole in the box will cause unfiltered air to go in the engine. The only place that I see that holes can be drilled is at the air intake of the ears around the square intake hole.
post #10 of 14 (permalink) Old 11-13-2007, 09:54 AM
You may be confusing the drilled airbox for the Triumph with doing it on the Vulcan.
On bikes that have the exhuast pipes coming from the front of the bike (ie: Triumphs, Nighthawks) the carbs are usually facing towards the back. The air intake is typically a box with a filter in it that sits under the front of the seat and back of the tank. Pretty restrictive air intake since all the air is coming in through a single hole in one side of the box. By drilling holes in the box you are allowing more air to flow to the carbs. The air still passes through the filter before going to the carbs.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
