Vibrations - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 11-05-2007, 03:32 PM Thread Starter
Vibrations
Hey, all. I have an '03 that has some vibrating issues. When I leave the bike running to warm up, I can see the mirrors and grips vibrating much more than I feel they should be. Also, the higher the RPMs I run the bike, the worse the vibrations get. It happens if I'm in neutral or when on the road, so I ruled out the tires.
Any words of wisdom? I'm starting to feel like I'm on a Hardley!
j0hn0tt0 is offline
post #2 of 10 (permalink) Old 11-05-2007, 05:43 PM
Joem's Avatar
This is just a shot in the dark, but have you checked all of your engine mounts to make sure none have worked loose. I think one of Fergy's mounts came all the way out earlier this year.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
post #3 of 10 (permalink) Old 11-05-2007, 06:27 PM Thread Starter
Where, exactly, are all of them?
j0hn0tt0 is offline
post #4 of 10 (permalink) Old 11-05-2007, 06:53 PM
Crobins365's Avatar
Hey, John -
Hope you haven't changed your pipes yet to round out that HD feeling!
You have three sets of through bolts: two are in the back of the engine block - one bolt comes through the block right under the front bevel gear case; the other sits above that, right behind the rear cylinder. I think they're 14 mm nuts - you'll want to retain one with a combo wrench while you use the socket wrench to loosen the other (or vice versa). Up front, there's a whole mounting unit that sits in front of the engine block - the through bolt goes in right around your shift lever and brake pedal, and then there are two smaller bolts that go part way through the frame and into the mounting unit. The through bolt is also a 14mm (I'm pretty sure), but the upper bolts are either 12mm or 13 mm (lucky me - I have one of each on Orleans!).
If those are tight, I might be thinking cam balancer dampers, but your bike is kinda young for that.
Crobins365 is offline
post #5 of 10 (permalink) Old 11-07-2007, 10:04 AM Thread Starter
I only had a minute, so I tightened one of the engine mounts on the front area and the vibrations have already reduced pretty substantially. Thank god it didn't turn out to be something much worse! I'll tighten the rest up tonight. Thanks for the help!
j0hn0tt0 is offline
post #6 of 10 (permalink) Old 11-07-2007, 11:07 AM
Joem's Avatar
Hey, thats the first time I've been right!! Good deal. Hope thats the only problem.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
post #7 of 10 (permalink) Old 11-07-2007, 12:45 PM
lol...
post #8 of 10 (permalink) Old 11-10-2007, 03:39 PM
borto1990's Avatar
I have an 04 thats doing the exact same thing.. some rides are worse than others.. in general, the bike runs great, 50+ MPG ect. sometimes however right around 4K RPMs seems to be the worse spot.. vibrates so much my foot tingles on the pegs. I've checked all my mounts, had several people help me make sure my carbs were in sycn ect and no luck.. I took it to the kaw dealer and they said it seems fine, however they are on 40 MPH roads and less.. right around 60 is where she's annoying. it started with 6K on the bike so it's hard for me to believe I'd have to take the engine down, but stranger things happen I guess..
Borto
2004 750
memphis shades windshield
chrome rad cover
chrome MC cover
chrome coolant cover
saddle bags
jardine sissy bar
protac back rest
jardine luggage rack
marbled
iridium plugs
R&R relocated
ram mounted quest GPS
Kaw engine guard
Tour Master XL sissy bar bag
bought 6/1/07 with 3200
currently just shy of 9000
as of 8-9-07
borto1990 is offline
post #9 of 10 (permalink) Old 11-10-2007, 09:35 PM
if it only causes problems at speed, and your dealer does not see a problem idling etc, could your tires be out of balance, round?
aradams is offline
post #10 of 10 (permalink) Old 11-16-2007, 04:45 AM
fuzz
my 05 vibrates so bad that the number plate is breaking in half , i have duct tape holding it togeather lol , i think i will check my mounts
fuzz is offline
