Doing research on MMO FEE SAMPLE - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 10-29-2007, 07:35 PM Thread Starter
dirtrack650's Avatar
Marvel Mystery Oil that is. I posted I like it and use it, but was not received with much - respect? - from a fellow member of VN750 so I'm researching the product.
Turns out that it is used to de-carbonize engines - aircraft
"Back in the late 1940s and early 1950s, at military air bases there were 55-gallon barrels labeled MMO (Marvel Mystery Oil). I forget the MIL spec number.... We had charts that told us how many gallons of MMO to put in per tank of fuel."
source - Robert Parker
Use the directions on the back for amount to put in the fuel per gallon of fuel (4 to 6 oz. per 10 gallons of fuel). MMO goes through the carburetor as a droplet, broken up like the fuel. When it enters the combustion chamber and the gasoline ignites, it is vaporized and soaks into the carbon buildup on cumbustion chamber walls, valve guides, around the valve stem, and on the spark plug. It soaks into the carbon and eventually loosens it up and it goes out the exhaust system.
go here for free sample:
http://landing.turtlewax.com/sept2007/
And finally read these threads from BMW - good for a beemer, works for me.
http://www.bmwmoa.org/forum/showthread.php?p=253569
dirtrack650 is offline
post #2 of 9 (permalink) Old 10-29-2007, 07:52 PM
Scoop's Avatar
My father who was in the automotive repair busniess (mechanic, machinist, service manager . . .) for 50 plus years swears by it! Does it really work? I don't know for sure but I use it and add a pint to most of my oil changes. To me it adds to the multi-viscosity of the oil.
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #3 of 9 (permalink) Old 10-29-2007, 08:00 PM
Blaze Orange's Avatar
I have used Marvel Mystery Oil in my 2006 750 since new. I only use it in the gas, I add a few ounces every tank full. I now have 10,000 miles and have never touched my carburaters, it is also a great upper cylinder lube when used in the gas. I'm glad its in there especially when she heat up s little on hot summer days when stuck in traffic, a little lube in the fuel saves wear. I haven't used any in the oil, I 'm concerned about clutch slippage.
Blaze Orange is offline
post #4 of 9 (permalink) Old 11-04-2007, 01:30 AM
It does seem to work In my earlier life as a mechanic when cars had carbs I have seen it work both in the gas and in the oil.it does wonders for cleaning out the returns in the heads.
gar616 is offline
post #5 of 9 (permalink) Old 11-04-2007, 12:40 PM
Sence I am one who has no "respect" for most of the "snake oils" on the market today , I'd be intrested in your test. Am not really sure how you plan to "test" this stuff , as you did not mention that, but I would guess you have two indentical bikes with the same milage on them and you plan to use the MMO in one , and not the other. Then ride each bike the exact same way for the exact same milage and then tear them down and look for a diffrence.
As tedious as this sounds, I do "respect" you for undertaking this test and finding out once and for all if MMO really does anything.
I however point out that in the 40's and 50's , they also thought ciggerettes were good for you and radiation was not that dangerous.
And to Blaze...I had a 2006 with the same miles and never "touched" the carbs either , but then I used Seafoam...
Anyway , anxiously waiting the results of you test.
Knifemaker
post #6 of 9 (permalink) Old 11-04-2007, 01:10 PM
85 VN 700
curtis97322's Avatar
I've used MMO, seafoam, and straight gas in my bike. I ride every day. The MMO seemed to make the bike happier, I'll probably pick up another bottle and see if some issues I've been having disappear again (they'll disappear with either seafoam or MMO in the tank, come back when they aren't in there... delaying the inevitable carb pull).
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #7 of 9 (permalink) Old 11-04-2007, 01:41 PM
I just want to clarify that I do believe that Seafoam, and possibly MMO , do a good job of keeping the carburators clean. Hell, even a good old Gumouit gas treatment should work here.
My contention that use of MMO in the oil, or that when used in the gas also keeps the engine clean is stretching it. All engines get some carbon build up, but after several thousand miles on my Vulcan ,I pulled the plugs, and they looked pretty damn good..this being owed to complete cumbustion in a somewhat lean engine and not attributed to the seafoam.
Other than keeping the carbs clean, being a guy from the "Show Me" state, you are going to have to offer me some pretty conclusive proof that MMO also does all the other stuff folks claim it does.
THNX.
post #8 of 9 (permalink) Old 11-05-2007, 08:18 PM
james brill's Avatar
Do any of you have to take emission test to get registered,and if you do ,do you test with mmo in your fuel,or do you test with fresh fuel?
james brill is offline
post #9 of 9 (permalink) Old 11-06-2007, 05:36 PM
Growling at the World...
bulldog485's Avatar
Send a message via Yahoo to bulldog485
I use MMO as listed on the can. It works. Seafoam will always be my #1 favorite, but MMO has it's uses too. To me, neither of them are "snakeoil".
Evan Breyn ~ The Bulldog
http://www.bulldogsbike.com
2006 Harley Davidson Ultra Classic FLHTCUI ~ The Big Black Bitch ~ 26,000 miles.
2002 Kawasaki Nomad 1500 ~ The Red Dog ~ Traded in at 22,000 miles of smiles (purchased new 10/05 / Traded in 6/12).
1990 Kawasaki Vulcan 750 ~ Black Betty ~ 34,999.7 miles
VROC ~v~ 485
McHenry County Road Pirates
Chicagoland, IL
bulldog485 is offline
