just a quick question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 06-23-2014, 08:30 PM Thread Starter
what does it mean when it says R/R relocated?
Thanks
Jmp
Jmpmstr1998 is offline
post #2 of 8 (permalink) Old 06-23-2014, 09:04 PM
Originally Posted by Jmpmstr1998 View Post
what does it mean when it says R/R relocated?Thanks
Jmp
The R/R (Rectifier/Regulator) controls your battery recharge rate from stator output....as needed.....What the battery does not need, the R/R sends to battery ground, which creates heat, ....the R/R needs to dissipate that heat.
The R/R is mounted beneath your battery box.....additionally adsorbing heat from the Goats Belly. Physically Relocating the R/R to the left rear frame allows R/R to catch more air (cooling) to stay cooler, thus eliminating future R/R failures do to heat.
....Requires a simple physical R/R Relocation mounting with a "U" bolt and flat stock to left rear frame (as pictured in many 750 pics) , No re-wiring required.
hth
post #3 of 8 (permalink) Old 06-23-2014, 09:52 PM Thread Starter
thank you.
post #4 of 8 (permalink) Old 06-24-2014, 01:29 PM
nicely done william
post #5 of 8 (permalink) Old 06-24-2014, 03:10 PM
"... thus eliminating future R/R failures do to heat...."
Ill just as here that there is no proof of this. It seems of course like a logical idea, but R/R units have failed both in the stock location and when relocated.
More stator failures have been reported than R/R failures...but there's been no conclusive evidence that relocating your R/R does anything more than just making you feel better....
post #6 of 8 (permalink) Old 06-24-2014, 03:35 PM
I'm agreeing with the knife on this one. I ordered the new shiny one from ebay and it made me feel better.
post #7 of 8 (permalink) Old 06-24-2014, 03:54 PM
I moved mine cause i lowered my bike and the swingarm was smackin it hard enough to break the battery box
post #8 of 8 (permalink) Old 06-24-2014, 06:01 PM Thread Starter
Thank you for the replies.
Will relocate this weekend and order new one for spare.
