Aftermarket STATORS? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 10-17-2007, 10:54 AM Thread Starter
Well I am pretty sure that my problem with my bike is my stator... Saturday I went out to the garage to try to start my bike and i got absoultely nothing no clicks, no lights, no nothing, the battery was 120% drained.
Is there a website or Place to go to get an aftermarket STATOR??? Or if i get the OEM one will I still be having a Problem???
no.1bearsfan is offline
post #2 of 5 (permalink) Old 10-17-2007, 01:28 PM
post #3 of 5 (permalink) Old 10-19-2007, 09:04 PM
Sky Rider's Avatar
Electosport sells aftermarket stators for 119 plus 15 for shipping and handling. 1 year warranty.
http://www.electrosport.com/shopping...od_esg050.html
Rick's sells theirs for 140 plus shipping. 6 month warranty http://www.ricksmotorsportelectrics....p?c=partLookup
A stock stator from Ron Ayers runs about 285 plus shipping. The stock stators are junk so I won't link the site here.
Neither Rick's nor Electrosport need the old stator so you can order the new one while pulling the old one.
Hope this helps.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 5 (permalink) Old 10-20-2007, 05:09 AM
Search Goddess
Dianna's Avatar
Rick's stators have a 1 year warranty same as most others
"We offer a One (1) year warranty on all parts (except CDI boxes). "
I have yet to hear of a bad stator from Rick's.
I would avoid Electosport (formerly Electrex)
Do the stator check first, twice really, once with a cold engine and then again after the engine has warmed up good.
Of course if you get bad readings with a cold engine the sevond test isn't needed.
Unplug and test the three yellow stator wires;
they should be .34 to .52 ohms between any
combination of the yellow wires, with no shorts to
ground.
If the stator check out good, it's a short somewhere probably or a bad CDI or fuse fuse box.
A bad ground wire or loose battery cable will drain your battery even while you are riding.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #5 of 5 (permalink) Old 10-20-2007, 11:06 AM
93VN750's Avatar
I installed a Rick's and it is a well made item. Been around transformers for decades, this one is made right.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
