broken broken bolt remover - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 10-16-2007, 10:03 PM Thread Starter
so im smoking crack in the garage earlier and im trying to remove a broken bolt from the frame of the basketcase. clearly i have been smoking too much and i was using the broken bolt remover (drill into bolt, insert remover and turn counter clock wise kind) and now I have the broken bolt remover broken inside the bolt hole. So the remover is hardened tool steel and is stronger than my carbide drill bits. any ideas other than to lay off the pipe?
newvn750owner is offline
post #2 of 9 (permalink) Old 10-16-2007, 10:12 PM
Scoop's Avatar
Is there enough of the broken piece or broken easy-out to weld to? If so, weld the threaded end of a bolt to it. This works well if there is enoght to get a good weld without messing up the rest of it. Good luck!
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #3 of 9 (permalink) Old 10-16-2007, 11:10 PM Thread Starter
not so lucky scoop. its broken inside the bolt hole.
post #4 of 9 (permalink) Old 10-16-2007, 11:15 PM
borto1990's Avatar
when this happens at work I've been able to use carbide burrs and grind it out.. takes some time but usually works. good luck!
Borto
2004 750
memphis shades windshield
chrome rad cover
chrome MC cover
chrome coolant cover
saddle bags
jardine sissy bar
protac back rest
jardine luggage rack
marbled
iridium plugs
R&R relocated
ram mounted quest GPS
Kaw engine guard
Tour Master XL sissy bar bag
bought 6/1/07 with 3200
currently just shy of 9000
as of 8-9-07
borto1990 is offline
post #5 of 9 (permalink) Old 10-17-2007, 01:41 AM
Maybe you can use a center punch to slowly break it up. Be sure to protect you eye balls.
post #6 of 9 (permalink) Old 10-17-2007, 09:00 AM
I usually try one of those two suggestions.
Like said, they can take some time, but there's not many other options.
When first drilling a hole for the remover, I try to find a proper sized lefthanded drill bit. Sometimes that works to get enough of a hold on the broken bolt to remove it and I don't have to try the remover.
You have to watch out with those removers. Too small and they snap easily. Too large and the more you try to turn counter-clockwise, the more it expands the bolt in the bolt hole.
Is it at all possible to heat the area around the broken bolt?
post #7 of 9 (permalink) Old 10-17-2007, 09:29 AM
Where exactey is this? I'm curious as to where your talking about. Is it something that could be replaced?
post #8 of 9 (permalink) Old 10-17-2007, 08:04 PM Thread Starter
the basketcase is just what I call the bike since thats how I bought it. a pile of parts in milk crates. p/o wanted to fix it up....you know how that goes. the broken bolt is in the frame where the rear fender mounts up. the remover did indeed shatter when it broke so im gonna try busting it out
post #9 of 9 (permalink) Old 10-17-2007, 11:11 PM
If it is possible you could have someone burn it out and bolt(longer)in the fender. I broke a tap in an exhaust manifold (Recesed In Bike) and a mechanic "friend" of mine told me I was F^@%*! So chisle, shim , shake, smack, bang... Good luck!
