Oil change? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 10-12-2007, 07:03 PM Thread Starter
Lebanon, NJ
Hiker's Avatar
Oil change?
Darn! Changed the oil today only to find a wafer thin ~1 1/8"th outside dimension, 5/8th" inside metal ring in the oil pan that I drained into? Is this some type of crush gasket? Where does it go? Did I waist 4 quarts of new syn oil?
Thanks....
Hiker is offline
post #2 of 5 (permalink) Old 10-12-2007, 07:13 PM
Rubline's Avatar
That washer sits on top of the rubber part of the oil screen. Its the second part to install. Screen first, then washer, then spring. Its so thin that I wouldnt think that you need to install it.
Rubline is offline
post #3 of 5 (permalink) Old 10-12-2007, 07:18 PM Thread Starter
Lebanon, NJ
Hiker's Avatar
Yea, that's what I thought. I ran the bike for 10 miles after the change and nothing leaks. I guess though that it might play a part in the separation of metal parts in the filter screen though?
What would you do? Leave it and run till next oil change or, drain and re-install?
Thanks Rubline for the timely reply...
Hiker is offline
post #4 of 5 (permalink) Old 10-12-2007, 07:42 PM Thread Starter
Lebanon, NJ
Hiker's Avatar
I drained and replaced the O ring and re-filled.
Hiker is offline
post #5 of 5 (permalink) Old 10-12-2007, 10:26 PM
Rubline's Avatar
its not the o-ring thats missing, its the metal washer right? Its not going to hurt anything if you run without it.
Rubline is offline
