Oil change? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 10-12-2007, 07:02 PM Thread Starter
Lebanon, NJ
Hiker's Avatar
Oil change?
Darn! Changed the oil today only to find a wafer thin ~1 1/8"th outside dimension, 5/8th" inside ring in the oil pan that I drained into? Is this some type of crush gasket? Where does it go? Did I waist 4 quarts of new syn oil?
Thanks....
Hiker is offline
post #2 of 4 (permalink) Old 10-12-2007, 10:07 PM
Crobins365's Avatar
Sounds like the right dimensions for your crush gasket (under the oil drain plug). Did you put it back on when you installed the plug, or no? If the latter, you might find a little leakage under there over time. Just keep an eye on it.
Crobins365 is offline
post #3 of 4 (permalink) Old 10-12-2007, 10:20 PM
Amsoil Man's Avatar
Hiker: I believe corbins is correct.Do you have a service manual..Get one if you plan on servicing your own bike..What type of SYN did ya use??When Ya drain out the oil to replace the drain nut nylon washer you can filter out any impuretys with a Automobile PAINT strainer.They are 20-30 microns and you will be safe.Im an AMSOIL dealer and We have to come with all sort of Ideas to reclaim oils like that..Talk soon...Amsoil Man
Pick ups reset
Splines lubed
Kenda Kruz tires 110Frt. / 170 rear
Custom saddle seat
Backrest
1500 classic rear fender
Cobra slants /Custom Made turndowns
Diamond Plate Buffalo Leather Bags
Throttle lock
Front bearings repacked
Front shock oil replaced
Led bulbs
Amp meter
Running Boards
Dial A Jet Carb settings
Gremlin Bell (front mount)
Fully Lubed with Amsoil Lubricants
Trailer hitch / Hidden
Your Local AMSOIL Connection! Cell#989-329-1225
Amsoil Man is offline
post #4 of 4 (permalink) Old 10-13-2007, 02:18 AM
It depends on where he drained the oil from. If it was from under the engine it's the cruch gasket. If it was from the side it's the washer that fits between the spring and oil screen. But, he did state it was wafer thin. I believe he drained the oil from the side and it's the washer that fits between the spring and oil screen. I think he already solved it in his other post.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
