will only start in neutral - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 02-10-2005, 10:44 AM Thread Starter
Was able to get my girl out for a ride on monday...had an unusually warm day for early february (u know how it is). Don't know how or why, but she'd only start if tranny was in neutral. There's a switch under the clutch lever and I'm wondering if it's possible that this switch may be bad? don't like the idea of stallin out in an intersection and having to find neutral for a quick re-start ! any thoughts?
Gary
grmpy is offline
post #2 of 4 (permalink) Old 02-11-2005, 07:45 AM
Search Goddess
Dianna's Avatar
Re: will only start in neutral
Does it do this from the start when it is cold or is it more of a warm restart problem?
My usual starting procedure is..
Cold start.. in neutral, full choke, no throttle
warm start or restart.. no choke, clutch in, flick of the throttle to catch.
Every once in a great while it seems she won't start up in neutral and I have the opposite problem.. clutch in, in gear, and she will start no problems!
Sorry, but I don't recall any instances where she would only start in neutral.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #3 of 4 (permalink) Old 02-11-2005, 12:42 PM Thread Starter
Dianna,
Your start procedure and mine are the same...problem here is that even when warm I have to put er into neutral. This hasn't happened before. Could always start er up with clutch engaged. I don't like the word assume...but there is this little switch on the grip housing that should get depressed when the clutch is engaged. I don't have a manual yet...so that's the assumption...that the switch, altho depressed, may be bad....and then will only start in neutral ? Kawi site (parts list) identifies it as part 27010-1094, but not what it does, but it has to be an electrical connection of some sort.
Gary
grmpy is offline
post #4 of 4 (permalink) Old 02-13-2005, 03:27 PM
Forum Faciliator
Red Baron's Avatar
If it starts in neutral but not when the clutch is pulled in, it sounds like the clutch switch is the problem. It is a safety interlock to make sure you don't try to start the bike in gear and get bucked off. :-)
RB
Red Baron
Binghamton, NY
Alright Already, Lets Ride!!
Red Baron is offline
