(trouble) SHOOTING Orleans - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 10-10-2007, 06:56 PM Thread Starter
Crobins365's Avatar
Angry (trouble) SHOOTING Orleans
Okay, I am home and here are the results:
All wires appear to be connected properly and tightly.
Carbs appear to be on the engine block ok. All ducts are also attached.
Battery was charged when I started.
With the gas tank on the bike, I had no fuel getting to the carbs. Opened the float bowls, and nada.
Took the tank off and injected 6ml of gas down each fuel line - still wouldnt start, but there was fuel draining from the bowls.
I'm at a loss....anyone else got any ideas?
C
Crobins365 is offline
post #2 of 12 (permalink) Old 10-10-2007, 08:32 PM
HAWK
Ccspinner's Avatar
You did make sure you have spark?
Was there any fuel on the plug when you tried too start?
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 12 (permalink) Old 10-10-2007, 08:35 PM Thread Starter
Crobins365's Avatar
I did check and have spark at all 4 plugs. Let me pull a plug from each cyl and see if they're dry. I did the spark check in the dark, so may have missed some crud.
Hey, sorry for not calling last night, too. Our client came to the focus group and wanted to chat, so I didn't get back to the hotel until late. I'm sure I'll be in MKE again, though!!
post #4 of 12 (permalink) Old 10-10-2007, 08:43 PM
You need fuel, good spark, and compression, for it to fire off.
post #5 of 12 (permalink) Old 10-10-2007, 08:45 PM Thread Starter
Crobins365's Avatar
All four plugs are dry as a bone.
I'm obviously missing vacuum...which could mean I'm missing compression. Anything obvious I should look for for that? I have a compression tester, but none of the leads that it came with is the right size for our bikes. So that's one trip to NAPA.
post #6 of 12 (permalink) Old 10-10-2007, 09:14 PM
Remove the plug that is not in the hole of the head, rear left, and see if you can cover the hole with your finger. If so turn the engine, but be sure to have the plug wire away from your hand, and if you feel any push from the air in the cylinder. Oh yes, be sure to unplug the other spark plug.
post #7 of 12 (permalink) Old 10-10-2007, 09:20 PM Thread Starter
Crobins365's Avatar
Yikes! And I guess I shouldn't be standing in water when I do this? Ha ha - let me go see what I can do to myself. Back in a flash. lol
Ow! Yes, it blew my thumb off, so I take that as a good sign?
post #8 of 12 (permalink) Old 10-10-2007, 09:35 PM
Sky Rider's Avatar
Yes, good sign.
Did you try to start with the choke on or off??
Can you smell gas in the cylinder??
It may just take a bit to get a good fuel/air mix into the cylinders.
Did you find your water in the crankcase problem??
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #9 of 12 (permalink) Old 10-10-2007, 09:37 PM
Are you using new spark plugs? I have rebuilt car engines and have had a time starting them. The problem turned out that I was using the old plugs that had been on the engine. The old plugs would not fire with the new higher compression.
post #10 of 12 (permalink) Old 10-10-2007, 09:41 PM
Also spray carb cleaner into the cylinder through the carb or even the spark plug hole and see if you get a fire off.
Spray into the hole and replace plug an try to start.
