Hitting bumps causing power failure - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 06-05-2014, 03:15 PM Thread Starter
Hi all,
I've been scouring the forums for possible solutions to a problem I started experiencing recently and can't seem to find anything that quite matches...
Yesterday while riding home, I hit a fairly standard-issue bump and immediately lost engine power; slowing very quickly while I attempted to restart. Other electrical seemed to be functional while the engine was dead - I could grind on the startor and even got it running again before I came to a complete stop. I believe I noticed the dash lights and similar were still functional when the engine power cut out. It started back up and promptly cut out again a few times, so I hopped off and took a look. I jiggled a few wires, disconnected and reconnected the plug caps and 2 visible wiring harnesses, and all was well for the rest of my 20 mile ride home.
It happened again today after traveling a bumpy section of road, so I'm thinking the bumps might not be a coincidence here? But I could be wrong. It seems more electrical than gas - but again, I could be wrong. When power is lost, it has cut out immediately and cleanly, and with some in-out-in-out choppiness before dying...
Where should I start checking for something loose or touching something it shouldn't be touching? Any help is greatly appreciated!
Thanks!
kms22 is offline
post #2 of 9 (permalink) Old 06-05-2014, 03:31 PM
Check all ground cables and make sure all connectors are clean and affixed securely.
Use electrical contact cleaner on connectors and pack them with dielectric grease to prevent moisture from getting back in.
post #3 of 9 (permalink) Old 06-05-2014, 03:35 PM
many have had odd or weird electrical gremlins that have been cured by cleaning the ignition switch as well
michiganteddybear is offline
post #4 of 9 (permalink) Old 06-05-2014, 03:36 PM
x2 on that!! Slim has a rebuild guide in the electrical section.
post #5 of 9 (permalink) Old 06-05-2014, 06:30 PM
x2 on all advice given. Electrical.
"When power is lost, it has cut out immediately and cleanly, and with some in-out-in-out choppiness before dying...".
A long shot but, If it happens again, pop the gas cap to eliminate possibility of POOGS. (wouldn't hurt).
hth
post #6 of 9 (permalink) Old 06-06-2014, 02:04 AM
Ndr
Possibly an issue in the ignition switch? Though I would still lean towards a loose ground wire somewhere.
Ndr is offline
post #7 of 9 (permalink) Old 06-06-2014, 02:25 AM
x2 ...my first thought & thinking it was already highly suggested....difficult to keep up with many threads....
post #8 of 9 (permalink) Old 06-06-2014, 10:41 AM
fergy's Avatar
What they said. Sounds like loose ground somewhere.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #9 of 9 (permalink) Old 06-06-2014, 02:32 PM
x5 ignition switch. tie wrap the puck tightly together after you clean it.
