vn700a parts - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 10-06-2007, 01:43 AM Thread Starter
Question vn700a parts
hello to all, i have a '85 700a and was wondering if the parts for a '86 750 were the same. i checked ron ayers microfisch and they dont list a 700. the kawasaki main sight has it but i am not finding coresponding p/n's. i am in GREAT need of a oil screen, the fisch showes a "filter assy" and a grommet and has two part numbers that start the same (16097-1058-filter assy and 16097-1054-grommet). the fisch showes these parts in a box. do i order both or what?? also need the clutch gasket outside, '85 700 p/n is 11028-1009 and the '86 p/n is 11060-1088, ayers has the '86 but no listing for the '85 p/n. any help in this matter will be greatly appreciated. almost forgot i need the p/n for the spark plug retainer oil rings as well. i cant find them at all. thank you. hoodrat
p.s.- i need to go riding!!!!!!!
hoodrat is offline
post #2 of 4 (permalink) Old 10-06-2007, 09:49 AM
As far as your spacifics (which parts where) If I haven't been there I wouldn't know & I'm not about to tell you something wrong. But! I do know the 700 is the prelifted tarrif version of the 750. Basically they are the same. Good luck hunting your parts!
post #3 of 4 (permalink) Old 10-06-2007, 09:55 AM
bj31702's Avatar
Send a message via Yahoo to bj31702
Oil screen at the dealer is less then 10 bucks. Look on the kawasaki site for the part numbers.
'09 Nomad e sold
'85 VN700 A1 (needs work)
'11 Voyager
bj31702 is offline
post #4 of 4 (permalink) Old 10-06-2007, 12:04 PM
Search Goddess
Dianna's Avatar
Order the 86 parts.
This might help for future reference
Changes to the VN750 over the years
If you have additions or corrections to this document:
- Contact: [email protected]
or
- a forum moderator
New Cost:
$5,500 (1985)
$5,500 (1987)
$5,500 (1988)
$_,___ (19__)
$6,090 (1995)
$6,090 (1997)
$6,090 (1999)
$6,190 (2000)
$6,190 (2002)
$_,___ (2006) =last year of production
Air adjustable forks
- '85-'88 = only years
Brake master cylinder
- '85-'90 = rectangular
- '91-'06 = round
Brake Lever
- '85-'90 = same
- '91-'06 = changed
Clutch lever is the same for all years
Engine color
- '85 only = black
- '86-'06 = natural aluminum
Engine isplacement
- '85 only = 699cc
- '86-'06 = 749cc
Fuel Ca latching
- '85-'87 = close without key
- '88-'06 = need key to close ????
Fuel Control Valve
- '85-'__ = RES - ON - PRI (Prime)
- '__-'__ = RES - ON - OFF
Fuel Tank rear vent tubes
- '85-'87 = none
- '88-'98 = tubes
- '99-'06 = none ????
Grab rails, Sissy bar, Passenger footpeg mounts
- '85-'86 = aluminum
- '87-'06 = chrome
Instrument bezels
-'85-'__ = aluminum
-'03-'06 = chrome
Mirrors
- '__-'__ = rectangular
- '__-'__ = round
Oil filter
- '85-'94 = larger size 2.95" diameter
- '95-'06 = smaller size 2.76" diameter
Oil filter (mating) plate
- '85-'93 = 13169-1921 = 2.95" (75mm)
- '94 = 13169-1921 = 2.95" (75mm)
- '94 = 13270-1170 = 2.76" (70mm)
- '95-06 = 13270-1170 = 2.76" (70mm)
Shock absorber
- '85-'98 = 45014-1304
- '99-'-6 = 45014-1710 older ProTac brackets may interfer with air valve
reported by Jim "Pick" Foster
Side covers
- '85-'86 = Ebony
- '87-'98 = Chrome
- '99-'00 = Gray
- '01 only = Bronze
- '02 only = Black
- '03 only = Red
- '04 only = Ebony
- '05 ____ = _____
- '06 ____ = _____
Wheels
- '85-'86 = painted
- '87-'06 = natural
Wiring harness
- '85-'88 have a Turn Signal Control unit
- '89-'06 Turn Signal Control unit eliminated.
- '85-'88 are NOT interchangeable with '89-'06 up
Won't work by leaving the signal circuit open
__________
- '__-'__ =
- '__-'__ =
__________
- '__-'__ =
- '__-'__ =
Paint color listing:
http://f1.grp.yahoofs.com/v1/MKNSQ_P...D08M/color.xls
A # Year Tank colors Side cover
A 1 1985 _______ / _____ Ebony _____-____ & ____
A 2 1986 Black / Red L.V. Red 36002-5183-P5 & 5184-P5
A 2 86 Black / White Ebony 36002-5181-H8 & 5182-H8
A 3 1987 Black / Gray Chrome 36001-1359 & 1360
A 4 1988 Ebony / Gray " " " "
A 5 1989 Ebony " " " "
A 6 1990 Maroon / Black " " " "
A 7 1991 Maroon / Black " " " "
A 8 1992 Blue / Blue " " " "
A 8 92 Green / Green " " " "
A 9 1993 Blue / Gray " " " "
A 9 93 Green / Green " " " "
A10 1994 Green / Blue " " " "
A10 94 Red / Red " " " "
A11 1995 Green / Blue " " " "
A11 95 Red / Red " " " "
A12 1996 Red / Gray " " " "
A12 96 Blue / Silver " " " "
A13 1997 Red / Gray " " " "
A13 97 Ebony / G. Silver " " " "
A14 1998 Bronze / Red " " " "
A15 1999 Ebony / Gray P.C. Gray Blue 36001-1284-VK & 1285-VK
A16 2000 Ebony / Gray P.C. Gray " " "
A17 2001 Graystone / Bronze M.D. Bronze 36001-1284-7R & 1285-7R
A18 2002 Black / Silver P.G. Black 36001-1284-86 & 1285-86
A19 2003 Red / Graystone L.V. Red 36001-1284-2T & 1285-2T
A20 2004 Ebony / Silver Ebony 36001-1284-H8 & 1285-H8
A21 2005 Ebony / Silver Ebony " " "
A22 2006 _______ / _____ _______ -
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
