03 vn750 oil plug - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-01-2014, 08:58 PM Thread Starter
Cool 03 vn750 oil plug
Hello all
can someone help i could not find oil plug for 03 vn750. all i can find is the regular plug. but mine is the one that goes to the side if the crank case not the bottom, also it is designed to set where it holds a spring and the spring hold a filtering screen. i looked every where eBay, Amazon, all web sites that sells Kawasaki parts but no luck,
Thanks
arman2500 is offline
post #2 of 10 (permalink) Old 06-01-2014, 09:07 PM
JM2001's Avatar
Originally Posted by arman2500 View Post
Hello all
Thanks
Kawasaki part# 11012-1483 oil filter cap. Search around for best price
http://www.kawasakipartsnation.com/o...ump-oil-filter
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 10 (permalink) Old 06-20-2014, 06:02 PM
berzerker1982-BL's Avatar
Now im wondering why my drain plug is on the bottom? 03 vulcan 750
berzerker1982-BL is offline
post #4 of 10 (permalink) Old 06-20-2014, 06:18 PM
The drain plug is in the side. They are all on th side. This is where you drain the oil, not the bottom. There is one on the bottom, but we don't use it.
post #5 of 10 (permalink) Old 06-20-2014, 06:45 PM
Really can i ask why there are 2 drains and why we use the side?
post #6 of 10 (permalink) Old 06-20-2014, 06:49 PM
Cause i just changed oil and drained it out the bottom.....is that bad?
post #7 of 10 (permalink) Old 06-20-2014, 06:51 PM
probably not bad thing (as in causing problems) but the side plug should have a filter screen in there to clean and inspect for debris, which can signal upcoming engine issues
michiganteddybear is offline
post #8 of 10 (permalink) Old 06-21-2014, 11:07 AM
Partshark.com
Cheaper but about 1 week delivery time.
Jmpmstr1998 is offline
post #9 of 10 (permalink) Old 06-23-2014, 10:22 PM
No one is quite sure why there is a drain plug on the bottom.
But putting your bike on the side stand makes that side drain the lowest point on the engine enabling the most warm dirty oil possible to drain out.
Also as mentioned by MI teddybear, you can pull the filter screen to inspect it for metal fillings or chunks of rubber, neither of which is good.
Metal filling indicate something grinding when it shouldn't be.
Rubber chunks will be signs of the balancer dampers getting brittle and disintegrating.
However early warnings may allow you to do repairs before either problem craters your engine.
post #10 of 10 (permalink) Old 06-24-2014, 01:24 AM
Ndr
Yeah, not sure why there are two plugs. The VN900 has the exact same two plugs. The 900 manual even says to stand the bike upright and use the bottom plug instead of the side plug.
Like most others though, I still like to use the side plug to be able to inspect the oil screen.
Ndr is offline
Tags
oil change , oil plug , oil screen
