Saving my bacon - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-31-2014, 04:45 PM Thread Starter
blackomen's Avatar
Saving my bacon
This site has saved me quite a bit of time and trouble with my Vulcan. The other day it was cutting off randomly. I did some research here and checked the harness connections under the tank. The ignition switch harness was loose and a couple other wires had nicks. It was still cutting off afterwards and checked back on here and figured out to clean the ignition puck. Which I promptly put the three dot copper deal back in backwards. So, I had to take it back apart and then it was fine. No more trouble with that.
Though this morning on the way to work the "pull" throttle cable snapped. I took the push one and moved it over to pull duty. Probably 5 minutes on the side of the road. An older gent on a newer wing stopped to see if he could offer a hand.
Nothing major has gone wrong with it so far, all these little maintenance things will get cycled through. New throttle cable is supposed to be here on Wednesday, can't wait. I definitely like the feel of the throttle a little better with both cables.
Silvia
MCCT's
Rick's stator
Heated grips
Accessory socket on handlebars
voltmeter
dark side nexen SB802 165/80R15
lubed splines
Tuxedo mod
900 seat
Dyna glide rear shocks
blackomen is offline
post #2 of 4 (permalink) Old 05-31-2014, 05:46 PM
Glad all is working out for you....Yeah, aged bikes....cables ..../whatever.... ALL wear out with time....two throttle control cables, I am all over that !
...years ago, At about 11 -12K miles, I replaced 4 (needing help) signal units, & ALL cables (as Preventive Maintenance).....no issues....no regrets.... it sucks calling a tow truck on a ruined ride.
ps; Beware of your "Balance Dampers" ! ( $45.00 and an engine pull) LOL
post #3 of 4 (permalink) Old 05-31-2014, 06:34 PM
And if you ever need a hand don't hesitate to drop me a line, I'm not that far away
post #4 of 4 (permalink) Old 05-31-2014, 09:27 PM Thread Starter
blackomen's Avatar
I installed a dvom on the handlebars to keep an eye on the stator, it runs pretty consistently at 14.4-14.5volts. I'm assuming the dampeners are good, the engine is fairly smooth. Something big will probably go eventually, but I'm not worried about pulling the engine. Appreciate the offer M_angell.
Silvia
MCCT's
Rick's stator
Heated grips
voltmeter
lubed splines
Tuxedo mod
900 seat
