Coolant leak in a baaad place! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-27-2014, 11:36 PM Thread Starter
On the right side of the bike (if you were sitting on it) where the engine case meets the front cylinder jug, I have coolant leaking through the main gasket. It just barely drips when the coolant system is under pressure.
So obviously, the only way to fix this is to pull the motor and replace the gasket between the case and the cylinder jug, but if I pull the motor and get into that far, why the hell wouldn't I just rebuild it?
The thing is, the bike is an 86 that sat it's WHOLE life, when I got it in late 2012 it had 3700 miles on it. I'm willing to bet now that I'm coming up on 10,000 miles all those gaskets and rubber parts that had dried out from sitting it's whole life are all on their way to failure, as well as the gasket that is giving me trouble.
Today I went and looked at a '99 a family friend owns, it's in great shape, and he only wants 1500 for it. I'm pretty certain I'm going to buy it so I'm not without a bike this season. I have a lot of trips planned.
The question is do I rebuild the old one? Or do I try to get rid of it for cheap? It NEEDS a rebuild to be worth anything to anyone. Is it going to be worth the trouble? I've watched a lot of Andrew Roth's videos and I'm pretty sure I could do it. Idk guys I need your guidance lol
Tuvoc is offline
post #2 of 5 (permalink) Old 05-28-2014, 12:38 AM
Go for It ! Great (winter ?) project which seems/sounds like you would enjoy !
Do it To It !
...with so few miles, I might expect mainly/only gasket replacement.
Valve Cover (molded rubber) gaskets are expensive, but few replace them ....when removed carefully.
oh, DO REPLACE THE BALANCE DAMPERS ! ($45.00)...beware, the Balance Gear Bolt is the only LH thead-ed bolt on bike.
enjoy
post #3 of 5 (permalink) Old 05-28-2014, 01:48 AM
Ndr
At this point, If you were looking to buy your friends bike, I would just keep and run that and hang onto your original for spare parts.
Break it down and shove it in a closet somewhere?
But as WilliamTech stated, most of the internal components probably wouldn't need replaced. You'd be looking at the gaskets, the most expensive of which are the head gaskets, and valve cover gaskets. (which might not even need replaced if your careful to put them back on the same head)
The balance dampers should definitely get replaced. As well as a handful of washers and o-rings.
Ndr is offline
post #4 of 5 (permalink) Old 05-28-2014, 07:44 AM
JM2001's Avatar
PM sent
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 5 (permalink) Old 05-28-2014, 08:51 AM
Or just deal with a little coolant leaking depending on how much. Slap some red gasket sealer or even a dab of JB weld over it and see if that slows it.
