pics of my lowering brackets: - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 09-27-2007, 10:30 PM Thread Starter
http://i35.photobucket.com/albums/d1...r/000_0039.jpg
http://i35.photobucket.com/albums/d1...r/000_0038.jpg
After a lot of work and help from an older neighbor man, he has a cutting torch, I came up with this. Got the idea from BMan. Thanx for all your help BMan.
Here is a pic of the bike.
http://i35.photobucket.com/albums/d1...r/000_0037.jpg
A bit dark but okay.
post #2 of 11 (permalink) Old 09-27-2007, 10:53 PM
HAWK
Ccspinner's Avatar
Cool, Did you lower the front end at all?
How does it ride now?
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 11 (permalink) Old 09-27-2007, 11:01 PM Thread Starter
It rides good. It is a little rough on the bit of gravel and dirt that I have to ride on to get to the paved road. It feels a bit top heavy. A matter of getting used to it. Did not lower front end.
Again I just have to say it. I am so glad to have been pointed in this direction (this forum).
post #4 of 11 (permalink) Old 09-27-2007, 11:18 PM
Scoop's Avatar
That looks great. I was looking at BMan's brackets earlier today thinking it was a good idea. How much drop did you actually get?
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #5 of 11 (permalink) Old 09-27-2007, 11:27 PM Thread Starter
I did not even measure the diff, but the tire is part up into the fender. there are about 2 to 3 inch gap. I set the shocks at 3 setting. At just over 115 lbs, I think I will be alright.
post #6 of 11 (permalink) Old 09-28-2007, 12:06 AM
Spriddle's Avatar
Very nice work,really looks good.
Steve from Pittsburgh
2005 vn750
modified knifemaker driver boards
chrome levers, Shaved saddle
Ape manual CCT's, nylon saddle bags
engine mount covers, plexIII windshield
crash bar w/floor boards, air hawk pad
ear mod, rad cover/,w/ss mesh
chrome cable and wire covers
chrome anti-freeze cover
RR relocation,MF battery,drilled out
idle plugs,marbled
Spriddle is offline
post #7 of 11 (permalink) Old 09-28-2007, 12:12 AM Thread Starter
Thanx, I want to buy a mirror repair kit and cut out the shape of the bracket and stick the chrome over the bracket.
post #8 of 11 (permalink) Old 09-28-2007, 02:25 AM
BMan23777's Avatar
They came out real good!!!mine came out to about 2 1/2"drop.As far as the shock setting I'm 180lbs and I have mine set at 2 with no problems. And your welcome!!!Anytime I can help!!!
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #9 of 11 (permalink) Old 09-28-2007, 12:46 PM
post #10 of 11 (permalink) Old 09-28-2007, 05:27 PM
Scoop's Avatar
Just curious - did you have to get a longer axle bolt? If so, where did you get it? And how long? How thick are the plates? 1/4 inch?
97 VN 750
R&R Relocated
Degoated
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
Scoop is offline
