98 750 has real bad starting problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-22-2014, 04:09 PM Thread Starter
could anyone send me any direction to fix this
has fuel and the battery is charged
Krobar is offline
post #2 of 9 (permalink) Old 05-22-2014, 04:11 PM
GloryRider's Avatar
What have you tried so far? Does the engine turn over? Have you checked the spark plugs, fuel petcock open, ignition on, kill switch set to run, etc?
GloryRider
Atlanta, GA
Current Ride: 1995 Vulcan 88 (1500A9)
Purchased Dec. 2014
approx. 6,800 miles
Previous Bike: 2000 VN750 "Glory"
With homemade stator
Details on stator build here
"Four wheels move the body. Two wheels move the soul"
"You live more in 5 minutes on a bike like this going flat out than some people live in their lifetime." - Burt Munro
GloryRider is offline
post #3 of 9 (permalink) Old 05-22-2014, 04:17 PM Thread Starter
engine turns over
i did check the outer part of the spark plugs it might be a good idea now that i think of it to take them out and check
fuel petcock is open
ignition is on
kill switch is set to run
1998 Vulcan 750
Krobar is offline
post #4 of 9 (permalink) Old 05-22-2014, 04:20 PM
Can you please describe what is happening in more detail. Does it stumble but not start, or just crank and crank?
My VN had really old spark plugs when I bought it, and would barely start after lots of trying. After swapping them to new NGK iridiums it started no problem @ all.
post #5 of 9 (permalink) Old 05-22-2014, 04:41 PM Thread Starter
mostly just cranking over with a little stumble
im going to try to swap out the spark plugs on it that makes the most sense
1998 Vulcan 750
Krobar is offline
post #6 of 9 (permalink) Old 05-22-2014, 04:45 PM
GloryRider's Avatar
You can test them before you swap them out by pulling one at a time, connecting the wire, and holding the threads up against the engine block while you hit the starter... if you get a nice fat spark, they're good...
GloryRider
Atlanta, GA
Purchased Dec. 2014
approx. 6,800 miles
post #7 of 9 (permalink) Old 05-25-2014, 06:58 PM Thread Starter
alright i swapped the spark plugs and petcock now it starts fine thank you
1998 Vulcan 750
Krobar is offline
post #8 of 9 (permalink) Old 05-25-2014, 07:56 PM
Glad we could solve your problem....
Now we would like pics of your ride...pls accommodate us !
We love pics !
tia
post #9 of 9 (permalink) Old 05-25-2014, 10:11 PM
Great news!
Tags
starting problem
