New Bars/Forks - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #21 of 29 (permalink) Old 07-31-2014, 11:40 AM Thread Starter
cycle zombie
asteroidasteroid's Avatar
@M_Angell
Yeah, everything looks and works great besides this problem. I'm not completely sold on the JB Weld idea yet. I haven't had a chance to look at it closer and see any cracks but it'll be at my house when I get home from work tonight..
asteroidasteroid is offline
post #22 of 29 (permalink) Old 07-31-2014, 08:40 PM
NEVER TO OLD TO RIDE
V750_outlaw's Avatar
2005 Kawasaki Vulcan 750
http://louisville.craigslist.org/wad/4594702789.html
99 vn750A15
stator mod and r/r mod
ignition coil mod
ignitor power circuit and ground circuit mod
ear shave rejet 142/42 plus .040 shimmed
vance and hines exhaust no baffles
custom paint
volt meter
petcock mod
new backrest and pad (no pic yet)
cooling fan cut off switch mod
jbm carb diaphrams (must have)
mcct mod
pickup coil mod
AGM Battery
did all the mods and repair work and custom paint myself. except exhaust.
V750_outlaw is offline
post #23 of 29 (permalink) Old 07-31-2014, 09:53 PM
That was some crash. Glad you didn't get seriously injured or killed. The damage still does not make sense to me. It must have hit something. Otherwise how could the front end have turned into a pretzel with no damage to the rear? Even the oil filter is dented. I would check the case where that sensor goes. It is made of fairly porous aluminum, which could still crack even after being welded. If it was damaged in the crash, it is likely to be more than stripped threads.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #24 of 29 (permalink) Old 08-01-2014, 12:38 PM Thread Starter
cycle zombie
Didn't hit anything but the ground. If it did, I probably wouldn't be talking to you right now. I think what happened was the forks twisted up and the front fender bent back and hit the oil filter & that oil pressure gauge. I've called two of the best shops in South Florida and they're both too busy to strip it and take the motor out, weld it and put it back together so I'm pretty much assed out of that option right now. Being a 99 most shops won't even touch it.
I investigated an engine swap, I found a 2001 engine with 8,000 on ebay for $600 shipped, but I'm guessing it'll be around $600 to get the original motor out too.
I could also try and drill out the hole, tap it and use a heli-coil like M_Angell suggested.
And theirs always the $10 JB Weld option.
With all the bad luck I've had with this bike since the crash I'm now dubbing it the Cursed Kawasaki Vulcan. It looks good but it's just a giant paper weight. On that note, who wants to buy this piece of sh**!? haha
post #25 of 29 (permalink) Old 08-01-2014, 02:13 PM
Dude why don't you pull the motor yourself? If I can do it anyone can lol.
BTW you could easily just tell them its a 2006...unless they check the Vin they won't know any different.
post #26 of 29 (permalink) Old 08-01-2014, 03:06 PM
Yeah its not that hard.had mibe out in abbout 2 hrs.
OleDirtyDoc is online now
post #27 of 29 (permalink) Old 06-11-2015, 06:27 PM Thread Starter
cycle zombie
Well it's been a while but I unscrewed the oil sensor and the casing around it just fell apart. The oil sensor screw was bent. Bought a new one and asked my Moms BF (who's an auto mechanic) to try and JB weld it, he thought it'd work. Didn't work. Probably looking at swapping the engine or buying a new Vulcan and swapping my new bars, wiring, exhaust to the new one..
ID:	23753   Click image for larger version
ID:	23761   Click image for larger version
ID:	23769   Click image for larger version
ID:	23777   Click image for larger version
post #28 of 29 (permalink) Old 06-11-2015, 11:10 PM
You could also take it to a welder and see if they could braze or tig that back together after you clean the jb off of it.
post #29 of 29 (permalink) Old 06-13-2015, 09:52 PM
Originally Posted by VN750Rider/Jerry View Post
That was some crash. Glad you didn't get seriously injured or killed. The damage still does not make sense to me. It must have hit something. Otherwise how could the front end have turned into a pretzel with no damage to the rear?.
Bike high sided and flipped be my guess. Seen it happen on a track. Front tire caught and the whole bike flipped end over end mid air and crashed front end
down. Bent the forks back into the motor.
