need some help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 139 (permalink) Old 05-21-2014, 06:13 PM Thread Starter
Glenn C.
gcextreme's Avatar
need some help
The bike started and ran fine 2 weeks ago...then i took the tires off...just got the new ones back on..now it wont start.
When the key is turned to on the right blinker on the dash is solid as well as the red oil light and neutral..nothing happens when i hit the start button.
When i turn the key to the "push" mark the blinker both will work..
Glenn C
Alexandria, MN
My VN750 Page
VN750 Stator Plates and Products
2001 Kawasaki Vulcan VN750
1986 Kawasaki Vulcan VN750 (being restored)
1986 Kawasaki 454LTD (being restored)
1985 Kawasaki 454LTD (being restored)
gcextreme is offline
post #2 of 139 (permalink) Old 05-21-2014, 06:40 PM Thread Starter
Glenn C.
gcextreme's Avatar
Ok i jumped it with my truck and got it started..but the right blinker indicator is on and its stuck on...not sure what would cause that..
Glenn C
Alexandria, MN
My VN750 Page
post #3 of 139 (permalink) Old 05-21-2014, 06:42 PM
First things first ....others will be asking/suggesting...
Is the bike in neutral ?
Did you pull the clutch lever in when attempting to start ?
Has the key switch been a little flakey anytime in the past ? If so, Maybe it is showing its ugly face now.
I s the battery still fully charged ?
First things first
hth
post #4 of 139 (permalink) Old 05-21-2014, 06:54 PM
I'm leaning toward a faulty key switch needing a rebuild.
Check your wiring as I see you have hardbags w/ blinkers built in. Is something grounding?
post #5 of 139 (permalink) Old 05-21-2014, 07:51 PM Thread Starter
Glenn C.
gcextreme's Avatar
I had the wires for the blinkers goofed up or crossed..fixed that..and that fixed the blinker issue.
Im thinking the battery is just dead...i charged it last weekend...
its a cheaper $70 sealed battery...i normally get 2-3 years from them.
Im gonna let it charge again overnite and try tomorrow after work..i gotta go to town tomorrow to get oil...may pick up a new battery while im at it.
Also what kinda oil u recommend... i normally run valvoline motorcycle 10w40.
Glenn C
Alexandria, MN
My VN750 Page
post #6 of 139 (permalink) Old 05-21-2014, 08:06 PM
NOT ANOTHER OIL THREAD! lol that being said lots of peeps use shell rotella t 15-40
Glad you got your electrics sorted out.
post #7 of 139 (permalink) Old 05-21-2014, 08:06 PM
I often buy Rotella T - Non Synthetic (Dino) 10w - 40 or 20w - 50
EDIT: 15w - 40 LOL
post #8 of 139 (permalink) Old 05-21-2014, 08:16 PM Thread Starter
Glenn C.
gcextreme's Avatar
Ok cool...may try switching to that...the bike only has 23,314 miles on it now.
Glenn C
Alexandria, MN
My VN750 Page
post #9 of 139 (permalink) Old 05-21-2014, 08:22 PM
Yeah I use the same here. What you're using is totally fine too. Whatever works, as long as it isnt "energy conserving" high mileage oil.
post #10 of 139 (permalink) Old 05-22-2014, 02:00 PM
Glenn....sounds like the crossed wires on the blinkers may have drained your battery.
Now that you have them fixed, your battery hopefully will charge and you should be back in business.
