Pulled the motor now its kaput - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 05-20-2014, 10:38 PM Thread Starter
air
Had to replace my stator on my 03 with around 23k on it.
Me and my boss pulled the motor out and replaced the stator as it was not charging. He was a mechanic for 10~15 years. I'm not a mechanic by any means. I do have some understanding of how things work. After replacing the stator and getting it all back together the bike dont act right.
I wouldnt start while I was at his house. We ran the battery dead and called it a day.
He got it started, but said it had some clanking like it was off time. It had done some clanking as it was trying to turn over when I was trying to start it. It would run at full throttle, but wont idle. Choking it floods the engine. Any idea's what we may have done incorrectly?
All of the hoses and wiring seemed to be correct. The are old and as I say had a memory (bent and curved) as they just fell into place where they should go. We didnt get into anything other than taking the side cover off and replacing the stator. We didnt touch the timing chains.
air is offline
post #2 of 11 (permalink) Old 05-21-2014, 12:19 AM
did you pull the front chain tensioner when you removed the side cover
if so that might not be positioned right or maybe you broke a wire to the pick up coils and its not running on both cylinders
or you didnt get the ground wire on the back of the motor on tight so its not getting a good spark cause of the faulty ground
just some ideas
post #3 of 11 (permalink) Old 05-21-2014, 12:45 AM
just some ideas
I could not have given this advice, but it sounds very logical to me.
Good post Trey.
post #4 of 11 (permalink) Old 05-21-2014, 12:31 PM
I was thinking pick up coils too. Mine broke not to long ago.
If one of the pick ups went bad then he shouldn't have spark right?
post #5 of 11 (permalink) Old 05-21-2014, 05:49 PM
or if he has the pickups installed in the wrong place (swapped) it might run badly if at all.
post #6 of 11 (permalink) Old 05-21-2014, 06:48 PM
....from reading OP past posts.... not at all...NO START
post #7 of 11 (permalink) Old 05-21-2014, 06:52 PM
Still probably the pickups, honestly. Either messed up a cable (has happened a lot on here I've noticed), or has em swapped.
post #8 of 11 (permalink) Old 05-21-2014, 07:03 PM
...You are sayin' just the electrical connectors/connections swapped while performing the maintenance.
post #9 of 11 (permalink) Old 05-21-2014, 08:51 PM Thread Starter
air
Thanks for the tips guys.
We are going to mess with it again sometime this weekend most likely.
We are going to check everything mentioned in the thread.
air is offline
post #10 of 11 (permalink) Old 05-21-2014, 09:00 PM
Best of luck air, looking forward to hearing the results.
