What Have You Done For Your Bike Lately - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 39 (permalink) Old 05-17-2014, 01:20 AM Thread Starter
Chuck A.'s Avatar
Guess I'll start this show. I had some tread left on the Metzler tires that were on the bike when I got it but being me I want to go with a new set. Michelin Commander II's went on the front and rear.
Chuck A. is offline
post #2 of 39 (permalink) Old 05-17-2014, 01:24 AM Thread Starter
Chuck A.'s Avatar
While doing the tires I went ahead and put new ceramic pads by a company call 'Sixty' on the front and rear. These are the EBC that came off the bike. Front are is good shape but the rears were pretty well used up.
Chuck A. is offline
post #3 of 39 (permalink) Old 05-17-2014, 01:26 AM
Originally Posted by Chuck A. View Post
Guess I'll start this show. I had some tread left on the tires that were on the bike when I got it but being me I want to go with a new set. Michelin Commander II's went on the front and rear.
While doing the tires I went ahead on put new ceramic pads by a company call 'Sixty' on the front and rear.
While the wheels were off the bike, why not put new seals and bearings in. 33,000 and 11 years on the others.
https://www.vn750.com/forum/album.php?albumid=1361&pictureid=8121
While we are at it, lets do the oil change.
Put the bags back on after the tire change and the left tail/brake lights did not work. Had the repair the wiring at the plug.
Routine maintenance on a bagger, ain't real routine is it Chuck? you should have pretty trouble free summer now. I pull that routine about the end of winter when I down mine for a week or two every year and it is a good time to find a lot of little things you don't normally see and head them off before they become a problem. You will like the Commander II's.
post #4 of 39 (permalink) Old 05-17-2014, 01:27 AM Thread Starter
Chuck A.'s Avatar
While the wheels were off the bike, why not put new seals and bearings in. ALL BALLS Brand. 33,000 and 11 years on the factory bearings but they felt like they were in great shape..
Chuck A. is offline
post #5 of 39 (permalink) Old 05-17-2014, 01:30 AM Thread Starter
Chuck A.'s Avatar
While we are at it, lets do the oil change. Still not up on full synthetic oils going in older dyno ran engines.
Chuck A. is offline
post #6 of 39 (permalink) Old 05-17-2014, 01:31 AM Thread Starter
Chuck A.'s Avatar
Chuck A. is offline
post #7 of 39 (permalink) Old 05-17-2014, 01:34 AM Thread Starter
Chuck A.'s Avatar
No Denny. This bike is a whole different animal. Just to get it off the ground safely is a new experience.
The bike had a 150/80/16 Metzler on the front when I got it. It was still in great shape. Put the 130/90/16 (Michelin) back on it as factory spec'd and it seemed to corner better and the tire isn't warn in yet.
Chuck A. is offline
post #8 of 39 (permalink) Old 05-17-2014, 01:42 AM Thread Starter
Chuck A.'s Avatar
Bike is done, lift is down, and tomorrow needs to come so I can put some miles on the new tires and brakes to wear them in. I miss the 750 but I'm loving this 1500.
Chuck A. is offline
post #9 of 39 (permalink) Old 05-17-2014, 08:33 AM
Big Nick's Avatar
Let the good times role. if I could be so bold, and it looks like your in the mood to do a few things, maybe one of them digi Volmeters on the top somewhere.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #10 of 39 (permalink) Old 05-17-2014, 09:45 AM Thread Starter
Chuck A.'s Avatar
Nick, I'd have to put 2 meters. One per stator. After I bought the bike Denny mentioned it had two. Yep, two r/r's sitting at the bottom of the radiator. Double trouble?
Chuck A. is offline
