Handle Grip - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 09-07-2007, 12:36 AM Thread Starter
Dan
Handle Grip
For some reason my left handle grip is sliding off the handle bar a little bit at a time. Maybe it is vibrating off(?) At first I could beat it back on by laying a little board across the end of the grip and beating it with a hammer. That doesn't seem to work anymore. What the heck is going on? The grip has slid off about one-half inch from where it used to be and doesn't want to go back. 2005 VN750.
Thanks - Dan
Dan is offline
post #2 of 12 (permalink) Old 09-07-2007, 12:57 AM
oglejust's Avatar
Thanks - Dan
if i were u i would prolly just lift up part of it and blow air w/ an air nossel into it to take it off. after taking it off wash it and the bars. put the grip on wet, but put hairspray on it also.
.... slightly modified
oglejust is offline
post #3 of 12 (permalink) Old 09-07-2007, 01:02 AM Thread Starter
Dan
Thanks Oglejust. I will give that a shot tomorrow. I have a little 3 gallon air compressor that might do the trick.
dan
Dan is offline
post #4 of 12 (permalink) Old 09-07-2007, 01:07 AM
oglejust's Avatar
dan
ya it dont take much air.... just enuff to lift the grip. u dont even have to do that if u can get the grip off w/o it.
oglejust is offline
post #5 of 12 (permalink) Old 09-07-2007, 01:15 AM
I put my grips on w hairspray. First rain ride I was caught in, the left one startd slipping off. Soon as everythign was dry I pullied it off, shot a tough of spray adhesie on it and slide it back on. I might have to cut it off later but I'd hate to be in a turn and it slips off in my hand.
vn750joe is offline
post #6 of 12 (permalink) Old 09-07-2007, 01:25 AM
oglejust's Avatar
true
oglejust is offline
post #7 of 12 (permalink) Old 09-07-2007, 03:40 PM
Mine is doing the same thing, but seems to be holding pretty good, only have to beat it back on about every couple of months... I think they are supposed to be glued from the factory... I know the Kawasaki shop sells a grip glue for about $2, guess I should get a tube and do mine also...
Thanks have a good one...Old Dog...
post #8 of 12 (permalink) Old 09-07-2007, 03:59 PM
You can use spray paint, it works great!
streetnit is offline
post #9 of 12 (permalink) Old 09-07-2007, 04:08 PM
Spriddle's Avatar
silicone caulking works great to
Steve from Pittsburgh
2005 vn750
modified knifemaker driver boards
chrome levers, Shaved saddle
Ape manual CCT's, nylon saddle bags
engine mount covers, plexIII windshield
crash bar w/floor boards, air hawk pad
ear mod, rad cover/,w/ss mesh
chrome cable and wire covers
chrome anti-freeze cover
RR relocation,MF battery,drilled out
idle plugs,marbled
Spriddle is offline
post #10 of 12 (permalink) Old 09-21-2007, 12:20 AM
You can also use a mix of water and dishsoap; helps them slide on a little easier and when the mixture dries, the soap acts like a glue but the "seal" is easier to break when or if you need to take them off.
95ladyrider is offline
