Removing both wheels - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 04-29-2014, 04:22 PM Thread Starter
Any issue I might expect? Was going to set the bike on stands. Might even run a 2x4 across between stands to form a stand. Need to have tires mounted so need to remove both wheels.
So thinking out bike on center stand. Raise rear and support on jack stand and then raising front. I have numerous jack stands and hydraulic jacks.
RobertGary1 is offline
post #2 of 14 (permalink) Old 04-29-2014, 04:27 PM
Deviate's Avatar
The first time I replaced my tires I had both wheels off. On the center and a jack under the front of the engine. Just make sure it's not wobbly and you shouldn't have any problems.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #3 of 14 (permalink) Old 04-29-2014, 05:46 PM
I did as Deviate .....but put a jack under the swingarm by the rear shock after I took the wheel off. This to avoid it fallng back if some neighborhood kid jumped on the bike or if my fat cat had the same idea.
Take the front wheel off first btw. You can then tilt the bike more forward to raise the rear so the rear tire clears the fender......
post #4 of 14 (permalink) Old 04-29-2014, 10:36 PM
I just use one of my handy dandy motorcycle lifts.
OleDirtyDoc is online now
post #5 of 14 (permalink) Old 04-30-2014, 12:06 AM
Dr. Vulcanstein
jadabull's Avatar
Both my wheels are off the bike right meow. I have it on the center stand and the forks resting on the concrete floor (engine is out as well) with a hand towel under the forks so they don't get dinged up.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #6 of 14 (permalink) Old 04-30-2014, 01:40 AM
Ndr
That's one...
Ndr is offline
post #7 of 14 (permalink) Old 04-30-2014, 02:40 AM
Dr. Vulcanstein
jadabull's Avatar
Originally Posted by Ndr View Post
That's one...
Glad someone caught that, lmfao!
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #8 of 14 (permalink) Old 04-30-2014, 06:25 AM
That's one...
Hahahahahahahaha
post #9 of 14 (permalink) Old 04-30-2014, 12:20 PM
Big Nick's Avatar
Straight over my head. Tell me what's funny?
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #10 of 14 (permalink) Old 04-30-2014, 12:25 PM
"Both my wheels are off the bike right meow"
In the movie Supercops? Two of the officers have a bet on how many times one can insert the word "meow" into the conversation when pulling a car over.
You're up to one.
(And I got two)
