Where do you get the pod filters? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-27-2007, 06:11 PM Thread Starter
I did ear surgery and need some kind of filters but it seems like the regular pods that go straight on would bump the bottom of the tank even though the filters are tapered.
I'm also wondering what carb adjustments/jetting issues I'm going to have.
Thanks for the help
holyman is offline
post #2 of 8 (permalink) Old 08-27-2007, 09:14 PM
Scoop's Avatar
Thanks for the help
I just did the ear shave as well and installed the cone shaped filters. The left side will just barely touch the tank when the tank is reinstalled. Per a suggestion in another thread on this topic, I shimmed the rear tank mount about 1/2 inch. Now the tank clears the filter by about 1/4 inch.
Scoop is offline
post #3 of 8 (permalink) Old 08-28-2007, 01:03 AM
BMan23777's Avatar
Scoop is right you have to shim the rear of the tank.What do you have for exhaust??? With my set up I had to re jet to-142 mains and 42 pilots on the tjets and 2 shims under the needles.
Got the pod filters from http://www.crc2onlinecatalog.com/pod_filters.htm you'll need the 54mm ones.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #4 of 8 (permalink) Old 08-29-2007, 06:14 AM Thread Starter
I have stock exhaust and don't have any plans to change that. I'm in Chicago area so I'm between 650 and 800 above sea level.
holyman is offline
post #5 of 8 (permalink) Old 09-06-2007, 01:39 PM
I orderd some pods and got them in just a few days.
Thanx Bman.
post #6 of 8 (permalink) Old 09-06-2007, 04:07 PM
dirtrack650's Avatar
Uni filters for me
These work great and save big bucks too.
http://www.polyperformance.com/atvsh...roductid=17445
dirtrack650 is offline
post #7 of 8 (permalink) Old 09-07-2007, 07:19 PM Thread Starter
How do you fit a 6 inch long foamy under the tank? You should oil a foam filter and that stuff gets everywhere {current Banshee owner } I like the idea of a foam filter but that thing looks like it would be a mess. Can you get an outerwear for it?
I saw these on eBay... too many but it's always good to have spares
http://cgi.ebay.com/ebaymotors/4-Air...1466QQtcZphoto
holyman is offline
post #8 of 8 (permalink) Old 09-07-2007, 11:30 PM
Short Socks
I found 2" foam that fit mostly under the tank. The oil on the foam is not an issue as long as you don't over do it and use the recommended brand. I usually clean them at the beginning and end of each riding season and have no problem even in the rain. I've always felt that K&N's or similar filters are way over priced. Multi colors too.
