Bike update and 2 questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 04-20-2014, 03:01 PM Thread Starter
Clone's Avatar
Hey Guys,
I just picked my bike from the shop yesterday. To remind everyone the bike had a leaky oil seal (PITA) and some other smaller questions and issues.
So I took it to that little bike shop and told the guy to look into carbs and all the other maintenance items, possibly look into this oil leak, and overall just give the bike a full inspection and check what else it might need.
He adjusted the carbs, replaced air filters, lubed a few things, pulled and cleaned the petcock, and lubed the front and back splines. And charged me $200 for it which I thought was very cheap. The oil seal stopped leaking by itself so for now I'll just forget about it. He also said he took it for a few long rides and it was all good.
So this is good. And I took it out today for a more serious ride and have 2 questions. Hopefully someone can answer these.
1. When the engine is under load I can hear a whine/whistle. It doesn't happen in neutral or at the same speed with the clutch so it's definitely something drivetrain related. It happens at any gear and is related only to RPM and load. It doesn't sound too bad and at about 4k RPM you can't even hear it any more. What can this be? Should I just ignore this or something is going to explode on me?
2. Up to about 4k RPM the bike has no vibrations. Around 4k it starts vibrating and the peak seems to be around 4.5k. The vibration is not violent by any means but it's there. At around 6k I would say that it's reduced. Is this normal for these bikes?
Other than that it seems to run good, shifts good and I don't see any other issues with it.
Clone is offline
post #2 of 10 (permalink) Old 04-20-2014, 03:16 PM
Crowley
crowley1027's Avatar
1) I think it's normal. Mine has the same sound.
2) balance dampers, or something like that. Little black rubber things inside your engine. There are threads about it. Google "site:vn750.com balance dampers"
crowley1027 is offline
post #3 of 10 (permalink) Old 04-20-2014, 03:33 PM Thread Starter
Clone's Avatar
I saw that thread. So this engine should not vibrate at all or some level of vibration is considered normal?
Clone is offline
post #4 of 10 (permalink) Old 04-20-2014, 03:53 PM
Crowley
I mean there are lots of moving parts, so vibration is inherent. It shouldn't be incredibly noticeable and if it's intense enough to mention something about it, chances are it's not normal.
post #5 of 10 (permalink) Old 04-20-2014, 05:00 PM Thread Starter
Clone's Avatar
Well, normally, at least with cars I'm very peaky about all kind of vibrations and I never owned a vtwin before. So I have no idea what is normal and what is not. The bike is usable the way it is. I didn't take it on the highway so I don't know how annoying it'll be at high speeds. Vibration is very slight and fast. And it's mostly felt in the right peg for some reason. Handlebars don't vibrate at all. Seat vibrates very very slightly.
I guess I'll call the shop again and see if he has any suggestions.
Clone is offline
post #6 of 10 (permalink) Old 04-20-2014, 06:17 PM
I haven't owned a bike of any kind that didn't have a vibration /tingle at a certain RPM range .That includes V-twins,inline 4's ,triples and parallel twins ,2 and 4 stroke. inclusive. Yours sounds normal to me. Vibration throughout the rpm range would be worrisome to me. I'd ride it like stole it unless it starts getting noticeably worse.Have fun,riding season is here.
post #7 of 10 (permalink) Old 04-20-2014, 06:32 PM Thread Starter
Clone's Avatar
Hey, sorry.. another question. PO replaced the stock exhaust with V&H but I just looked and it seems that he bolted the mufflers to a little metal bracket that is mounted directly to the frame. It doesn't make any sense to me. Basically it's transferring all the vibrations from the engine to the exhaust and to the rear peg mount.
Shouldn't there be some sort of rubber mount in between the muffler and its mount???
Clone is offline
post #8 of 10 (permalink) Old 04-20-2014, 07:41 PM
Is it the mount the footpegs are mounted to? They normally mount to the rear footpeg mount and there is a rubber bushing inside
post #9 of 10 (permalink) Old 04-20-2014, 09:49 PM
Deviate's Avatar
My thoughts on the vibration are this...the engine vibrates normally. If you have a lot of vibration (gauges and mirrors vibrating so much you can't focus on them or the bike bounces on the center stand across the garage floor or the foot pegs vibrate so much your foot about falls asleep) AND you see rubber bits in your oil....it's time to pull the engine for the balance dampers. If you just have a really bad vibration but no rubber in the oil...look for something else like the engine mount dampers. If it's just a little vibration with no rubber in the oil...just ride it.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #10 of 10 (permalink) Old 04-20-2014, 09:58 PM
Chasin' the blacktop
Spencer1's Avatar
X2 Just ride it and check your oil screen for rubber bits.
North Georgia
Spencer1 is offline
