I swear this oil is teleporting from somewhere.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 04-11-2014, 04:38 PM Thread Starter
Because I cant find the source of the leak lol
I have a small oil leak. I thought it was the o ring on the side oil plug. I found out by replacing it that it was not lol Then I decided to go through and snug up all of the bolts on that side of the motor. I thought that did the trick, but after a short 2 or 3 miles as soon as I stop and get off the bike there is that pesky drip. Coming right off of the side oil plug. It will drip 5 or 6 times once stopped. I cant find where it is actually coming from. And if it throws 5 or 6 drips after shutting her down...I am guessing it is throwing it while riding as well.
Anyone with advise please help lol
tat2brad77 is offline
post #2 of 9 (permalink) Old 04-11-2014, 05:11 PM Thread Starter
post #3 of 9 (permalink) Old 04-11-2014, 05:13 PM
The side plug is a cast piece....it may have a crack in it from over tightening it....finger tight is all you need if the seal is in good shape.
It may also be the starter seal that is seeping and the wind from riding blows it back towards the oil drain plug and drips from there since that is a low spot.
post #4 of 9 (permalink) Old 04-11-2014, 05:14 PM
Put some clean paper under any part you think may below the leak. Haven't tried it , but was told you can coat the side of the suspected area with talcum powder to help pinpoint a leak. Don't assume it's coming from the bolt, it might be just collecting there.
I had a freind that swore his was leaking on the left side of the bike, turned out gasket on the right was leaking and when he put it on the sidestand at night, it was just running to that side.
I've never owned a bike that leaked oil, but I wish you luck with your search.
post #5 of 9 (permalink) Old 04-11-2014, 05:33 PM
i had a teeny tiny seep from the o-ring for the stator cover... its on the proper side of the bike for a leak at the drain plug...
removed the stator cover, cleaned o-ring, grove in the cover it seats in, and mating surface.. no more leak
michiganteddybear is offline
post #6 of 9 (permalink) Old 04-11-2014, 08:50 PM
Big Nick's Avatar
Try the other sump plug in the centre of the sump, might be the culprit.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #7 of 9 (permalink) Old 04-11-2014, 10:38 PM
Chasin' the blacktop
Spencer1's Avatar
My oil filter loosened up on my once. Oily starter with some drips dropping out from under the crankcase.
North Georgia
Spencer1 is offline
post #8 of 9 (permalink) Old 04-11-2014, 11:07 PM Thread Starter
I found the leak...just under the stator cover there are two 8mm bolts. Right behind the frame where the kick stand is. It is ever so slightly seeping out there. Too small of a spot for a socket. Gonna put the wrench on it tomorrow and see if they need snugged. ..If not then either a new gasket or some type of sealant for the outside.
post #9 of 9 (permalink) Old 04-25-2014, 06:24 AM
Bobber Junkie
Madame Mohawk's Avatar
Send a message via Skype™ to Madame Mohawk
Did that fix it? I'm curious to know; Just had some maintenance stuff done on my bike, including two seals, and she's still leakin' oil.
This is my Vulcan. There are many like it, but this one is mine.
Thunderhorse 86 VN-750
Single mirror conversion
Cafe bars
New forks, lowered (Thanks Deuce!)
VN-900 seat (Them hips don't lie!)
Vintage bags
Gas mask 'fairing'
Radiation symbol on tank
On the list
Earshave/rejet
Underglows, light bar
Custom paint
Radiator cover
Pipes
Turn Signals
Grips
Horns
Fixing that damn oil leak
Madame Mohawk is offline
