Throttle and clutch cable - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 04-09-2014, 09:45 PM Thread Starter
notmechanical
Unhappy Throttle and clutch cable
I switched my bars and now have lots of slack in both cables, and everything is crammed in, do I need to buy or can you buy shorter cables? Can I cut them? It looks like there's a piece that is broke off on the return throttle that is supposed to slide into the throttle to return it? Just bought the bike last year and barely been able to ride it. I hate not being mechanically inclined.
chardcastle is offline
post #2 of 10 (permalink) Old 04-09-2014, 10:24 PM
Chasin' the blacktop
Spencer1's Avatar
As long as each cable is not stretched out (unlikely) and each cable sheave black plastic cover with metal ends) end is securely fastened the longer cable won't make any problems. I wouldn't suggest cutting them, then you loose the metal sheave ends that securely hold your cable sheave ends securely. You would also loose the "ball" on the end of each cable making secure attachment almost impossible.
North Georgia
Spencer1 is offline
post #3 of 10 (permalink) Old 04-09-2014, 10:29 PM Thread Starter
notmechanical
One "ball" is broken off because I actually did stretch the cables I believe trying to not take things apart as much as I should because I suck at things like this. It's the return throttle ball so that's an issue too. It returns but is scary to ride not knowing which is why I stopped riding it.
post #4 of 10 (permalink) Old 04-09-2014, 10:31 PM
If the bike has Ape hangers installed w/o longer cables.... may be your issue.
Slim is an expert on the subject.....pm "SlimVulcanRider", or wait for his response here.
...and there many others who will respond with answers.
Have you you met up with/or ride with other VN750 riders in your state ?
post #5 of 10 (permalink) Old 04-09-2014, 10:34 PM Thread Starter
notmechanical
The bike did have ape hanger like bars and I put a super cross straight type bar on it. Both styles in my profile
post #6 of 10 (permalink) Old 04-09-2014, 10:42 PM
No, I will NOT ride with a broken Throttle return Cable (safety device)......either.
post #7 of 10 (permalink) Old 04-09-2014, 11:38 PM
Proud owner of 2 VN750s!
Yankee's Avatar
Since one is broken anyway, I'd replace both cables. Plus, I'd check your ignition switch as well.
Yankee is offline
post #8 of 10 (permalink) Old 04-10-2014, 12:09 AM
x2
I replaced ALL cables on my '86 bike. No issues....no problems.
post #9 of 10 (permalink) Old 04-10-2014, 01:16 AM
you could cut them, if ya know how to solder new barrels onto the ends of the cables... you can also splice em to make them longer.. if ya know how to solder the barrels...
Here is a write up I did on making custom cables from scratch.
post #10 of 10 (permalink) Old 04-10-2014, 08:31 AM Thread Starter
notmechanical
Thanks everyone
