Pulsating chirping at 3000 RPM's - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 08-18-2007, 12:56 PM Thread Starter
Tcat1000's Avatar
Unhappy Pulsating chirping at 3000 RPM's
Hi......2006 with 4000 miles. At 3000 rpm's, it has an horrible "Chirping" "Tweetie Bird" noise coming from the engine somewhere. It sounds like the left side. It is very loud! It sounds like a 40 pound Canary riding on my left side, chirping his fool head off. It is so annoying, I cannot ride at that speed. It starts coming on at 2500 & leaves completely at 3500. It is not the tank vent. At 3000 rpm's if I pull in the clutch, it goes away. If going down a grade at 3000, it mostly goes away. At 3000 rpm's steady speed or a slight uphill grade, it chirps like crazy. It is not my windshield, cables or on the outside. It seems to be internal. It also seems to be related to the clutch system. I can ride all day at 3500 (55mph) or higher) & nothing. If I back down to 50 MPH (3000 rpm's) it comes back with a vengence!
It has gotten to the point that either the chirp goes, or the bike will. It's that bad. It has done this almost since I had the bike, but has gotten worse. Other than that, it runs & starts perfect.
Anybody??????????????
No, I'm not taking it back to my dealer. "Mother Teresa" knows more about mechanics than them..............
Tcat
[email protected]
2006 VN750
Splines lubed With TSMOLY 70
R&R Relocated
Marbled (Cat's eyes no less)
Digital Volt, Amp, Temp gauge (Kisan)
Pipes Drilled
Carb Adj. at 3 3/4
Polaris AGM Battery (190 CCA)
Kaw rear rack
Kaw front engine guard
National Cycle Street Shield EX W/S
Mobile 1 MX4T 10W40 oil (Now labled 4T Racing)
Purolator PL14610 oil filter (Painted)
Iridium Spark Plugs
Pulsating Brake Light (Kisan)
My Motto: Don't get mad, just get even. Trust me, I will get even!
Tcat1000 is offline
post #2 of 12 (permalink) Old 08-18-2007, 02:33 PM
HAWK
Ccspinner's Avatar
Check your heat shelds, I had a noise like that on mine and found the sheld was loose.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 12 (permalink) Old 08-18-2007, 03:47 PM
"ya can't live forever"
artman's Avatar
Ditto
artman is offline
post #4 of 12 (permalink) Old 08-19-2007, 12:09 PM
My chirping was the same culprit as the above. same RPM range also but wasn't as loud as you claim yours to be.
Woody is offline
post #5 of 12 (permalink) Old 08-19-2007, 12:55 PM
Benjammin'
BSkaggs513's Avatar
I have the same chiping. Was there a particular heat shield that you looked at? What did you do to remedy it?
Thanks!
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #6 of 12 (permalink) Old 08-19-2007, 02:36 PM
Growling at the World...
bulldog485's Avatar
Send a message via Yahoo to bulldog485
Originally Posted by Tcat1000 View Post
Hi......2006 with 4000 miles. At 3000 rpm's, it has an horrible "Chirping" "Tweetie Bird" noise coming from the engine somewhere. It sounds like the left side. It is very loud! It sounds like a 40 pound Canary riding on my left side, chirping his fool head off.............
Tcat
[email protected]
Have you looked for a Canary in your engine? Little buggers can be elusive
I would tend to agree with everyone else. Those heat shields can be a bugger if they are loose. But on the other hand, you don't want to make them too tight either as that can result in the hold-downs busting when the engine cools. Double edged sword - can get cut either way...
Evan Breyn ~ The Bulldog
http://www.bulldogsbike.com
2006 Harley Davidson Ultra Classic FLHTCUI ~ The Big Black Bitch ~ 26,000 miles.
2002 Kawasaki Nomad 1500 ~ The Red Dog ~ Traded in at 22,000 miles of smiles (purchased new 10/05 / Traded in 6/12).
1990 Kawasaki Vulcan 750 ~ Black Betty ~ 34,999.7 miles
VROC ~v~ 485
McHenry County Road Pirates
Chicagoland, IL
bulldog485 is offline
post #7 of 12 (permalink) Old 08-19-2007, 02:39 PM
Sorry, but I don't remember what I said about this when I emailed you about it.
Have you had the seat and tank off? Might be something under there vibrating.
But the heat shields would be a good place to check first.
Pulling in the clutch, as well as coasting down a grade, removes the force of the engine to the drivetrain, which would inturn reduce whatever is vibrating. I don't think the noise is related to the clutch, other than that. (meaning the clutch is probably working just fine)
Can you get the noise while the bike isn't moving, by reving the engine to 3000rpm's?
post #8 of 12 (permalink) Old 08-19-2007, 10:41 PM Thread Starter
Tcat1000's Avatar
Hmmmmm
Thanks for the replies............I sure hope it's not internal. I can't believe it is coming from the shields or something rubbing together. Evidently others are having the same problem too. My buddy has a 2004 & we switched bikes for about 10 miles the other day. When we rolled into his driveway, his statement was........"I wouldn't ride that S.O.B. again with that chirping noise blasting in my ear". His does not do it at all. Lucky me................
He didn't believe me on how bad it is until he rode it.
Again, it comes at 2500........is very loud at 3000, & quits at 3500 completely. The above never changes. The shields are tight, but I guess it don't mean they or something else isn't rubbing together causing the noise. Maybe I will pull the shields off & take it for a spin.
To answer the question of reving the engine at 3000 RPM's.......I have done that several times & no noise at all.
It don't make any sense to me that it will chirp like hell all day long at 3000 rpm's but at 3500 or higher all day long, there is no chirp at all.
One thing that I have noticed..........There isn't any or much of a chirp until the enging warms up or maybe about three to five miles.
Again.....thanks for all of the replies. Any more will also be appreaciated!
Tcat
2006 VN750
R&R Relocated
Pipes Drilled
Carb Adj. at 3 3/4
Kaw rear rack
Iridium Spark Plugs
Tcat1000 is offline
post #9 of 12 (permalink) Old 08-20-2007, 07:20 PM
My right side sheild was the culprit, took forever to get rid of the noise.Narrowed it down for sure when I removed the shield and then rode it. Put it back on and it was fine after that.
Woody is offline
post #10 of 12 (permalink) Old 08-20-2007, 07:42 PM
bulldog485's Avatar
Well done!!!
VROC ~v~ 485
Chicagoland, IL
