vibrations at higher RPM's - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-15-2007, 05:00 PM Thread Starter
borto1990's Avatar
Hey everyone.. I am starting to get vibrations at higher RPM's. I can feel it in my pegs and in my hands sometimes.. if I lean the bike to the right and left I get it more than going straight. goes away when pulling the clutch in. anyone have any ideas what to check.. I have a 5 hr ride coming up friday! Thanks
Borto
2004 750
memphis shades windshield
chrome rad cover
chrome MC cover
chrome coolant cover
saddle bags
jardine sissy bar
protac back rest
jardine luggage rack
marbled
iridium plugs
R&R relocated
ram mounted quest GPS
Kaw engine guard
Tour Master XL sissy bar bag
bought 6/1/07 with 3200
currently just shy of 9000
as of 8-9-07
borto1990 is offline
post #2 of 8 (permalink) Old 08-15-2007, 07:31 PM
Calif Rider
weh44att's Avatar
By the way you explained the problem, it does not seem to be in the tires or the drive shaft. If it goes away when you pull the clutch, then most likely it is in the engine. As for what it would take alot of checking to find the problem. Maybe timing? Not much help sorry. You may try the Sea Foam and see it that maybe a easy fix, at least a cheap one if it works.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 8 (permalink) Old 08-15-2007, 09:18 PM
Dan
What kind of condition are your tires in? Before I got new tires I would get vibration when I banked in a curve; the steeper the bank, the more the vibraton. It got worse as the tires got worse. With my new tires I have no vibration.
Dan is offline
post #4 of 8 (permalink) Old 08-15-2007, 09:27 PM
Check your motormounts and make sure thay are tight. Other than I would make sure it is good tune.
Woody is offline
post #5 of 8 (permalink) Old 08-15-2007, 10:12 PM Thread Starter
borto1990's Avatar
thanks.. is there a torque specs for the motor mounts? the one by the seat that goes all the way through I moved with a wrench (didn't have one on the other side yet though) without much effort. As far as the tires, this is probably the last season. Got 9K on them. still look good, seem to be wearing evenly but I can see small small cracks starting to form like in the bottom of the tread lines.
Borto
2004 750
chrome rad cover
chrome MC cover
saddle bags
jardine sissy bar
protac back rest
marbled
iridium plugs
R&R relocated
Kaw engine guard
as of 8-9-07
post #6 of 8 (permalink) Old 08-15-2007, 10:19 PM
Crobins365's Avatar
The torque specs for the front mounting bolts and right-hand side bracket bolts are: 24 N-m, or 17.5 ft-lb. The sub-frame bolts and nuts are 44 N-m or 33 ft-lb. And the through bolts and nuts are also 44N-m or 33 ft-lb.
That may not be the source of your vibration, but it can't hurt to check those periodically.
C
Crobins365 is offline
post #7 of 8 (permalink) Old 08-15-2007, 11:34 PM
HAWK
Ccspinner's Avatar
I would look into syncing the carbs.
Cindy had a good homemade tool for that.
She can explain it better.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #8 of 8 (permalink) Old 08-16-2007, 07:54 PM Thread Starter
borto1990's Avatar
Ok, thanks everyone.. well I've tightened down everything I could see and all seems OK.. If it is indeed a carb "sync" issue does anyone have a pic of the manometer tool? read threads about it but saw no pics. Also, what causes carbs to go out of sync. will it run bad, bike seems to run fine. also, if they are out of sync, what harm will come about if I run like that. I have a 400 mile journey tomorrow.. Thanks!
Borto
2004 750
chrome rad cover
chrome MC cover
saddle bags
jardine sissy bar
protac back rest
marbled
iridium plugs
R&R relocated
Kaw engine guard
as of 8-9-07
