Two questions - one electrical, one coolant pipe - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 26 (permalink) Old 08-12-2007, 08:04 PM Thread Starter
Crobins365's Avatar
I'm in the process of putting Orleans' engine back in the frame, and realized I'd forgotten to solder the pickup coil wires on the harness (bought a used wiring harness on eBay and the seller had cannibalized that set of wires). Soldered 'em well enough, but I can't seem to figure out how to get the male ends out of the connector to put shrink tubing on. Soooo, I used a lot of electrical tape. Is that ok, or is there some magical property to shrink tubing that it should be on those wires? (also, if someone could tell me how to get the male ends out, that'd be cool....)
Secondly, I reassembled the engine, got the right hand crankcase cover on, it's all "Right Stuffed" and everything (did that Friday). Then realized (clearly, I'm having sequencing issues...) that I hadn't put the coolant pipe back in place. Clymer's suggests that it can be put in even after the cover is on the bike, but for the life of me, I don't know how. The two ends are also different - anyone know which one goes up to the cylinders, and which one goes down to the crankcase?
<sigh> The Reconstruction of Orleans is just not gonna be easy...
C
Crobins365 is offline
post #2 of 26 (permalink) Old 08-12-2007, 09:25 PM
Wish I could help ya here, Cindy, but it was probably over 1000 post's ago that you'd already done more with the Vulcan than I have!! LOL
I'll try to hone in on your frustrations (I guess I could use proper Vulcan terminology and say 'Mind Meld' with ya LOL) and get an idea for an appropriate avatar for ya!!
post #3 of 26 (permalink) Old 08-12-2007, 10:09 PM
I prefer heat shrink because electrical tape glue tends to loosen when it get hot in my experience. It also leaves a residue when it is removed. Electrical tape to me is good enough. Heat shrink leaves a impression of quality. Just my opinion.
diswill is offline
post #4 of 26 (permalink) Old 08-13-2007, 07:09 AM Thread Starter
Crobins365's Avatar
Once I started using shrink tubing, I kinda preferred it, too, for all the reasons you stated. Any tips on pulling the leads out of the connector housing??
C
post #5 of 26 (permalink) Old 08-13-2007, 08:31 AM
There is a silicon stretch tape you can use. It bonds to itself without adhesive and is suppose to make a water tight seal. Withstands temps to 500 degrees. You can find it in the plumbing section at home depot. I've used it to wrap electrical connections and to fix a leaking water joint.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #6 of 26 (permalink) Old 08-13-2007, 09:54 AM Thread Starter
Crobins365's Avatar
Thanks! I'll see if I can find that tape - definitely sounds better than all the stuff I slapped on the solder points last night.
C
post #7 of 26 (permalink) Old 08-14-2007, 09:54 AM
I'll take a look tonight. That was the first thing I had to deal with when I bought my bike . That right side case was leaking, so to replace that I also had to remove and install that pipe. I'll let you know.
post #8 of 26 (permalink) Old 08-14-2007, 10:48 AM Thread Starter
Crobins365's Avatar
Thanks, Jason. So far a rubber mallet hasn't done the trick...
C
post #9 of 26 (permalink) Old 08-14-2007, 12:42 PM
I just took a look at the motor i toasted on the way to carlisle, and on the pipe, the flared end of the pipe runs into the sidecover. So far as I can see, that's the only difference in them, but you're right, it's probably a significant one!
-Kenny-
djphibes is offline
post #10 of 26 (permalink) Old 08-14-2007, 01:52 PM
As for the pipe, it does look like it'd be a bit tricky to do with everything together.
This is the one with two o-rings on each end?
Have ya tried putting the o-rings in one hole, and at the other end put the o-rings on the pipe. Then apply some silicone lube and try to work things back together?
