Need help after lowering - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 08-11-2007, 08:38 PM Thread Starter
BVP
I had a pair of lowering brackets made and I installed them on the bike. The new height is perfect since I am only 56. As I was making some turns today I notice a scraping noise. My first thought was it was the Dynas I put on, but then realized it was the center stand hitting the ground in the turns. Has anyone else had this problem and if so what did you do about it. I figure my choices are 1. Dont lean so much in the turns (this makes for very wide turns), 2. Remove the center stand (this will cause a bit of inconvenience during those times when I need to center stand the bike), 3. Raise the bike back up to stock (which I would rather not do).
Bob
Lompoc, CA
96 VN750 Red/Black
Dyna Mufflers
Cheap Windshield
33+K miles
BVP is offline
post #2 of 7 (permalink) Old 08-11-2007, 11:37 PM
HAWK
Ccspinner's Avatar
It will be harder to get on the center stand with a lowered bike, removing it may be a option.
Do you still have the goat belly?
if so you may be able to cut off the stopper to raise the center stand a bit.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 7 (permalink) Old 08-12-2007, 12:41 AM
BMan23777's Avatar
I haven't had this issue on mine.But I have MAC pipes on mine so as Chad stated My centerstand tucks up a bit higher now.So you might want to give Chads idea a try and cut the stop off or remove the goats belly all together.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #4 of 7 (permalink) Old 08-13-2007, 09:02 PM Thread Starter
BVP
Still have the goat. I removed the stopper and all is good. I am still able to get it onto the center stand, it takes a little more leverage but it is possible. Thanks for your help
Bob
Lompoc, CA
96 VN750 Red/Black
Dyna Mufflers
Cheap Windshield
33+K miles
BVP is offline
post #5 of 7 (permalink) Old 08-13-2007, 11:01 PM
HAWK
Ccspinner's Avatar
If you need to get onto the center stand you can roll the rear tire on a 2X6.
That will lift the rear a little and may be easer to get on the center stand.
Chad Falstad "Hawk"
Vroc #17649
post #6 of 7 (permalink) Old 08-14-2007, 01:47 AM
BMan23777's Avatar
Rolling it up on a 2x6 works great!!!!
Brian Manchester
'89 "GRIMM"
04 durango AWD
post #7 of 7 (permalink) Old 08-14-2007, 07:24 AM Thread Starter
BVP
O.K, I now have a 2x6 next to my toolbox. If I don't set it aside I will use it for some other project. Thanks again for the info, one less hernia is always good.
Bob
Lompoc, CA
96 VN750 Red/Black
Dyna Mufflers
Cheap Windshield
33+K miles
BVP is offline
