NEED HELP a.s.a.p. ??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 29 (permalink) Old 03-28-2014, 11:44 PM Thread Starter
fixinit1's Avatar
Need some help PLEASE with sugar and anything else you want. DONT want to miss another riding season. Back round: Tuxedo mod complete, TPE stator installed, Mosfet R/R and relocated, pickup coil re-gapped and repaired(broke during stator replacement) new used CDI box, repaired relays in JB and checked according to manual, coils tested according to manual but had bad boots( since our screw on) replaced wires with new until the ACCEL ignition coils and wires show up (April 2 tentatively), and new Autocraft AGM battery 1 week old as of today, ACCT to MCCT done, and last but not least iridium spark plugs. Problem: it studders when in gear and about 4000 to 5000 RPM's but when in neutral there is no studder. Please dont say check connection I already did that twice with continuity test, cleaned and checked again, cleaned all grounds twice. starts great hot or cold, have 14.3 at battery at idle and 11.3 volts at coils all sparks are firing and check hot and cold. ( by hot i mean ran bike long enough to have cooling fan come on). I'm thinking carburetors but I have never had problems with them before, always ran a little sea foam in my tanks. BUT bike did sit for about 5 months while working on it and retreiving from divorce. Please help I really don't think it electrical but I'm out of Ideas
fixinit1:
AGM battery
TPE stator
Mosfet R/R
Re-gap pickup coils
iridium plugs
Accel coil & wires
acct to mcct
replaced relays in JB
GPS & 12v outlet
saddle bags
fixinit1 is offline
post #2 of 29 (permalink) Old 03-29-2014, 12:04 AM
[QUOTE=fixinit1;646257]Need some help PLEASE with sugar and anything else you want. DONT want to miss another riding season. Back round: Tuxedo mod complete, TPE stator installed, Mosfet R/R and relocated, pickup coil re-gapped and repaired(broke during stator replacement) new used CDI box, repaired relays in JB and checked according to manual, coils tested according to manual but had bad boots( since our screw on) replaced wires with new until the ACCEL ignition coils and wires show up (April 2 tentatively), and new Autocraft AGM battery 1 week old as of today, ACCT to MCCT done, and last but not least iridium spark plugs. Problem: it studders when in gear and about 4000 to 5000 RPM's but when in neutral there is no studder. Please dont say check connection I already did that twice with continuity test, cleaned and checked again, cleaned all grounds twice. starts great hot or cold, have 14.3 at battery at idle and 11.3 volts at coils all sparks are firing and check hot and cold. ( by hot i mean ran bike long enough to have cooling fan come on). I'm thinking carburetors but I have never had problems with them before, always ran a little sea foam in my tanks. BUT bike did sit for about 5 months while working on it and retreiving from divorce. Please help I really don't think it electrical but I'm out of Idea
Your fresh Gasoline is 100% for minimum 90+ of days...no sweat.
Nothing major here....run it !
I am with you....not electrical... Carburation ! (carb's)
Suggest you try Seafoam (per )(side of can instructions) for a tank of fuel - 87 Octane....... works wonders.....
hth
post #3 of 29 (permalink) Old 03-29-2014, 12:49 AM Thread Starter
fixinit1's Avatar
Thanks. I thought of that. so i drained everything put fresh gas with sea foam in it... went about five miles with it..got alittle better but not by much think i just need to ride and hope it clears.. or pull the carbs and do a cleaning
fixinit1:
AGM battery
TPE stator
Mosfet R/R
Re-gap pickup coils
iridium plugs
Accel coil & wires
acct to mcct
GPS & 12v outlet
saddle bags
fixinit1 is offline
post #4 of 29 (permalink) Old 03-29-2014, 01:34 AM
Ride her a little then clean carbs if she don't clear up
post #5 of 29 (permalink) Old 03-29-2014, 01:39 AM
Yea ride her around. Maybe a little funk built up in the carbs. Maybe add more seafoam in the next tank.
post #6 of 29 (permalink) Old 03-29-2014, 01:44 AM
These bikes get pIssed when ya don't ride them
post #7 of 29 (permalink) Old 03-29-2014, 03:38 AM
You can take the bottom of the carb off where the jets are if you have a short screwdriver & a small ratchet. The jets could have build up.
Does it rev good in nutral, just bad under a load?
post #8 of 29 (permalink) Old 03-29-2014, 05:53 AM
Mcneuby's Avatar
Air Vent Hose
On your carburetor there is a vent hose that goes to a dead spot on one of the ears, If it isn't placed in the right place it will hesitate around 40 to 50 mph.Make sure that hose is in the right place in dead air. From my own experience I know it seems like it can't make that much difference, but it does.Search vent hose and you will get more information
Mcneuby
New to me 2004 15k Last liscened in 2011. Stock as they come.
Mcneuby is offline
post #9 of 29 (permalink) Old 03-29-2014, 10:45 AM
When it shudders, if you open it up, will it take off?
wmsonta is offline
post #10 of 29 (permalink) Old 03-29-2014, 05:50 PM
...Ellijay huh ?...set me up with Dagmar Midcap and I'll fix and customize yer bike fer nuthin.....paint too...
....honestly....try doin a backblow on the carbs...proceedure is in the stickies in the carb section....75% of the time, it works...worth a try....
