New bike. What to do? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 07-27-2007, 02:50 PM Thread Starter
Hey, guys! I went out and bought a 2003 750 the other day (my first bike, period). The only thing is that it's been sitting for about a year. From reading around, I gather that if the bike has been sitting, I should change all the "fluids". Can someone tell me which fluids have to be changed, exactly? Also, can you link me to something that it should be changed with? I know squat about motorcycle maintenance but would like to start off on the right foot.
Thanks a bunch guys, I love this site.
P.S. I read some things in the Vulcan Verses about changing fluids, too, but I'm still not entirely sure what, exactly, will need catering to.
P.S.S. I checked to see if the battery is a MF, and it seems to be. There's a sticker on top saying something like "this is a sealed battery, no water needs to be added" or something to that effect. I'm guessing this is a MF, right?
j0hn0tt0 is offline
post #2 of 16 (permalink) Old 07-27-2007, 03:39 PM
HAWK
Ccspinner's Avatar
You are correct that is a MF batt.
I would start with adding some seafoan to the tank, Change the oil, make sure you use good oil. If it says Friction modifiers or Evergy conserving DON"T USE IT.
That is bad for our wet clutches.
Check your drive splines and change the diff fluid, it is Gear Lube 75W90 will work fine.
Check your Brake fluid and see if it is clear or brown, should be clear.
Finaley the Coolent would not be a bad thing to do.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 16 (permalink) Old 07-27-2007, 03:49 PM Thread Starter
Thanks for the info, Ccspinner. What's a good oil that anyone here could recommend? Should I go synthetic?
As far as coolant goes, does it take anything special?
Like I said, my knowledge on motorcycle, and automotive maintenance in general, is pretty limited, so I really appreciate the words of wisdom.
j0hn0tt0 is offline
post #4 of 16 (permalink) Old 07-27-2007, 05:41 PM
When it comes to dino or synthetic, it's pretty much a preference thing. I'm using Shell Rottela T 15W40 and noticed smoother shifting than the 10W40 Kaw oil. You will need a little less than 4 qts. Make sure the bike is on the center stand when filling the oil. DO NOT OVERFILL. The oil level should be between the high and low marks on the sight glass.
I'm also using a Bosch 3323 filter. A little longer than the Kaw filter. I can't remember what I paid for the Kaw filter, the Bosch was $5.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #5 of 16 (permalink) Old 07-27-2007, 10:44 PM Thread Starter
Awesome.
So, regular coolant then?
j0hn0tt0 is offline
post #6 of 16 (permalink) Old 07-27-2007, 11:04 PM
Lebanon, NJ
Hiker's Avatar
Originally Posted by j0hn0tt0 View Post
Awesome.
Have looked at the versus yet? https://www.vn750.com/forum/forumdisplay.php?f=36
Hiker is offline
post #7 of 16 (permalink) Old 07-27-2007, 11:20 PM Thread Starter
Oh, I missed the thread on coolants.
Thanks for reminding me.
j0hn0tt0 is offline
post #8 of 16 (permalink) Old 07-27-2007, 11:20 PM
Awesome.
Yep, regular, as long as it's safe for aluminum engines.
post #9 of 16 (permalink) Old 07-27-2007, 11:29 PM Thread Starter
Got it. I'll try to get this all done over the weekend. Thanks again guys!
I noticed one other thing. I was sitting on the bike before while it was off and on the centerstand when i noticed that the clutch had about an inch of play in it before it would tense up and feel like it was actually doing something. Is there anything I should check/do?
j0hn0tt0 is offline
post #10 of 16 (permalink) Old 07-27-2007, 11:47 PM
According to the shop manual, there should be 2-3 mm (.078-.118 in) of play.
If those numbers are confusing to ya, it should be a little less than 1/8 of an inch.
If the adjusters are tightened all the way, ya may need a new clutch cable.
Take a look where the cable goes into the hand lever also, to check for any fraying.
But on an '03, the cable should still be good.
