wont start after stator replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 03-03-2014, 02:13 PM Thread Starter
emtdon's Avatar
just got everything back together but wont start. does the exhaust have to be hooked up to start? was just checking to see if it would fire. got the pipes on but not the goat belly. didnt have an extra hand at the time. put iridium plugs in, cleaned all electrical, seems to be getting fuel. pickup coils test on the ohms meter showing around 44 while not running of course. it will try to run for a couple of seconds but dies almost immediately. any advice welcome. i did coaster and plugged the vent line from the carb that went to the emissions thing under the seat.
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #2 of 14 (permalink) Old 03-03-2014, 02:46 PM
Should at least run without goat's belly.see if it'll run on starting fluid.check to see if the vacuum line is hooked up to the petcock.
post #3 of 14 (permalink) Old 03-03-2014, 10:30 PM
Crap, I WAS in 5th gear.
A bad pickup coil can cause this condition. 44 ohms is too low- from memory it should be around 400 give or take.
Kelly2001 is offline
post #4 of 14 (permalink) Old 03-03-2014, 11:37 PM Thread Starter
emtdon's Avatar
that's what i was afraid it was cold today so as soon as it warms up i guess i will recheck them. its gonna suck to have to pull the engine again. but next time will be easier lol.
Sent from Motorcycle.com App
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #5 of 14 (permalink) Old 03-04-2014, 01:06 AM
Make sure you're checking it right- if you were reading 0.44 Megaohms- that would be 440 ohms, or about right. Also, if you do need to replace one pickup, you can solder one in just by removing the stator cover.
Pull the spark plugs and crank it with the electrode near a cylinder head- if you hear an audible pop and see a spark, there is likely no problem with the pickup coil or ignition for that matter.
Check your float level, too. When our CVK carbs sit they tend to gum up.
post #6 of 14 (permalink) Old 03-04-2014, 01:25 AM Thread Starter
emtdon's Avatar
so if i have to solder one i would just clip the wires solder and heat shrink? is there a special type of heat shrink i should use due to heat and oil. i was hoping i could do that but was afraid it wouldn't stay insulated due to the heat. or would an epoxy work like what is used on the stator wires. sorry lot of questions at one time.
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #7 of 14 (permalink) Old 03-04-2014, 09:14 AM
Yep, just solder the wires together. At a minimum, you would want to use a polyolefin heat shrink, which is fuel resistant and suitable for 275F applications. There are heavier duty hest shrinks, but not required. I think you can get the 3M stuff at Napa.
post #8 of 14 (permalink) Old 03-04-2014, 01:49 PM
before you go rewiring things.....make sure you didn't reverse the locations of the pickup coils.
It will not run if they are in the wrong locations.
post #9 of 14 (permalink) Old 03-04-2014, 03:27 PM
You should get the exhaust buttoned up as well. Lack of back-pressure can affect idle.
post #10 of 14 (permalink) Old 03-05-2014, 12:17 PM
Excellent KC !
