shocks & tire pressure - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 07-20-2007, 07:06 PM Thread Starter
Rider on the Storm
EasyRector's Avatar
Question shocks & tire pressure
My bike is more heavily loaded than usual for my upcoming trip. I normally set the shocks at setting 2; I usually run 30 psi in the front tire and 34 in the back (stock Bridgestones). I know I can experiment, but does anyone have any general advice about making shock/tire pressure changes with a heavier load?
EZC
EasyRector is offline
post #2 of 3 (permalink) Old 07-20-2007, 08:33 PM
Rubline's Avatar
I set the air pressure according to the manual. I also have my shocks with 30lbs of air pressure in them. You might want to stiffen the dampening.
Rubline is offline
post #3 of 3 (permalink) Old 07-20-2007, 10:47 PM
Max pressure to put in the shocks is 43 psi. Use a hand pump to SLOWLY pressurize them or you could blow the seal. Rule of thumb is take estimated weight and pressurize to 10% of that (if the weight is 300 pounds, add 30 psi).
The dampening will be more of a feel thing. Bump it up to 3 and see what it feels like. If it doesn't feel right, go to 4.
As for tires, I run mine about 2 psi below max pressure the tire is rated. Makes for a comfortable ride.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
