Can I use an impact driver on the float bowls? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 06-30-2007, 10:08 PM Thread Starter
Crobins365's Avatar
Okay, here's why I ask: when I cleaned the carbs on McKnight, they were a wreck - totally gummed up with varnish. I wasn't able to remove (and clean) the float bowls because I think the screws on each were varnished on tightly. So I cleaned everything else and hoped for the best. Took McKnight out this evening, and I'm pretty sure my float bowls are stuck open (a little throttle goes a long, long way). Dumped some Seafoam in, started the engine to move it through the system a little, and will see what tomorrow brings. But assuming I'm still getting too much fuel, I'll need to pull the carbs and somehow break into the float chambers. Can I use an impact driver to loosen those screws? Or am I gonna make a greater mess of things doing that? If "greater mess" is the response, anyone got any ideas for getting those screws out? I learned from Orleans that tugging at a 'pry point' does not loosen those screws, but will crack the aluminim around them...
C
Crobins365 is offline
post #2 of 13 (permalink) Old 06-30-2007, 10:15 PM
HAWK
Ccspinner's Avatar
If you are careful a Impact driver might work, try light taps first.
Sometimes teh vibration is all you need
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 13 (permalink) Old 06-30-2007, 10:24 PM Thread Starter
Crobins365's Avatar
Thanks, Chad. I guess if I'm overzealous, then I'll be looking at a JB Weld job again...
C
post #4 of 13 (permalink) Old 06-30-2007, 11:26 PM
Probably not much else ya can try if they're that tight.
Just like Chad said, start lightly. If they don't break loose easily, the vibes may work some of the Seafoam in better, then try again a little later.
post #5 of 13 (permalink) Old 07-01-2007, 02:21 AM
Growling at the World...
bulldog485's Avatar
Send a message via Yahoo to bulldog485
Those damn screws that they use for the carbs are so freaking soft. Every time I take apart a carb, I usually end up replacing all the screws as half of them end up getting the heads all messed up from just removing them.
Evan Breyn ~ The Bulldog
http://www.bulldogsbike.com
2006 Harley Davidson Ultra Classic FLHTCUI ~ The Big Black Bitch ~ 26,000 miles.
2002 Kawasaki Nomad 1500 ~ The Red Dog ~ Traded in at 22,000 miles of smiles (purchased new 10/05 / Traded in 6/12).
1990 Kawasaki Vulcan 750 ~ Black Betty ~ 34,999.7 miles
VROC ~v~ 485
McHenry County Road Pirates
Chicagoland, IL
bulldog485 is offline
post #6 of 13 (permalink) Old 07-01-2007, 10:09 AM Thread Starter
Crobins365's Avatar
Gosh, I'm glad to hear you say that - I was thinking it was me, but they really are mushy aren't they? Which, I guess, is also why they oxidize easily or do whatever to firmly attach themselves to the threads. I guess I can also sploot the chambers with acetone and see if that at least dissolves the build-up on the outside (but I'll have to accept whatever consequences befall the insides....).
C
post #7 of 13 (permalink) Old 07-01-2007, 12:58 PM
fergy's Avatar
I know this is probably painfully obvious to most, but I figure there may be some newbie wrenchers that need to know... A Phillips head screw doesn't mean any phillips head screwdriver will fit. There are way too many variables in my opinion in the heads of these screws and using a slightly wrong bit or screwdriver tip is a sure path to boogering up a screwhead. Especially on carbs where the screws are kind of important to have the right ones for the fit, test several different tips on the screws and find the one that fits the most snug and has no slop. That will help to keep from chewing out the inside of a phillips screw, "almost" every time.
Cindy, I'm certainly not saying you used the wrong tip. Just thought I'd point it out since I know we have wrenchers from both ends of the scale here!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #8 of 13 (permalink) Old 07-01-2007, 03:04 PM Thread Starter
Crobins365's Avatar
THanks, Fergy, that's a great point - alas, when I had the carbs off before, I played around with various drill bits to get the best fit, and that one didn't budge the screw. Didn't strip the inside of it, either, just didn't move it.
Anybody got any gaskets for the float bowls that they want to sell? Just in case??
C
post #9 of 13 (permalink) Old 07-01-2007, 11:29 PM
PB Blaster will take care of those screws within a few days, almost guaranteed. I tinker on things almost daily for friends and family and it is the best stuff I have ever used. Just spray it on good, then wait overnight or a day or two if it's really bad and it'll do the rest! Can get it at almost all auto stores.
Hope it helps!
http://www.pbblaster.com/
Tyger is offline
post #10 of 13 (permalink) Old 07-02-2007, 06:05 AM
2FAS4U
https://www.vn750.com/forum/showthread.php?t=4302
Links to JIS phillips screwdrivers.
2fas4u is offline
