Rear Shocks Adjust? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 06-10-2007, 11:52 AM Thread Starter
Question Rear Shocks Adjust?
OK, I'm showing how little I know about my bike. But if I don't ask I'll never learn. How do the rear shocks work, AKA Adjust. I see the numbers, the air valve so whats the deal. Does it stiffen and soften the ride? I'm lov'n the bike but I deffinetly need to know more. Thanks.
post #2 of 9 (permalink) Old 06-10-2007, 12:34 PM
85 VN 700
curtis97322's Avatar
air valve stiffens the ride. Rule of thumb is to have 10% of the total weight of rider and passenger in the shocks if you are above 150 lbs.
I.E. I'm around 250 lbs - so I run around 25 ft lbs of air pressure.
The numbers adjust the rebound - seems like there's something in the verses (I'm having a brain fart)
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #3 of 9 (permalink) Old 06-10-2007, 01:13 PM
Drive less, ride more...
theauhawk's Avatar
Correct me if I'm wrong on this someone, but to add air pressure to the rear shocks, it's best to use something like a bicycle tire pump or some sort of hand pump only.
Using any sort of powered air pump will quickly overfill the rear shocks, and damage the seals--they simply don't take much air.
As with the tires, check the pressure in the shocks when they are "cold".
Even the owner's manual says to inject air in the shocks slowly....
theauhawk is offline
post #4 of 9 (permalink) Old 06-10-2007, 03:27 PM
85 VN 700
ohh... forgot to add that part <g> glad ya caught it theauhawk - the air bladder in the shocks is tiny and takes a tiny bit of air. Using an unregulated powered air source will blow the bladder real quick.
What I did - but don't necessarily recommend - is set the regulator on my air compressor to the pressure I wanted - check same pressure with a known good gauge - turn off the compressor just in case - and add air. Definitely taking a risk should both gauges fail - but It worked and pressure was what I wanted it to be when I checked... keep in mind that checking pressure causes the shocks to loose pressure.
The other option - and probably the safest - is to use a hand pump. Should be less than 10 pumps per side - seems like it was around 5 pumps on my tiny bike pump (the type ya carry on the bicycle).
Ammo Can Saddlebags
post #5 of 9 (permalink) Old 06-11-2007, 12:11 AM
Progressive Suspension makes a hand pump with a gauge installed (GP2 Guage Pump. Model GP2-0-60). Not sure how much it goes for. I borrowed one from a friend of mine. The manual only has a chart going up to 43 PSI, but a note later on states to not exceed 71 PSI since it could damage the oil seal. I don't think I'd go over 43 PSI.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #6 of 9 (permalink) Old 06-11-2007, 08:03 AM
Red face
Great info! Been wondering how to handle this since:
A - I'm 250lbs and the suspension needs to be working well to handle that!
B - Using a hand gauge changes the pressure!!
So, I just ordered a 0-100 lb Progressive unit from Dennis Kirk for $53 including shipping.
This board is an incredibly useful site for learning the 'how -to' stuff for our bikes! Thanks to all who contribute.
mngunner is offline
post #7 of 9 (permalink) Old 06-11-2007, 08:42 AM
2FAS4U
I weigh about 160-165 and run mine on #2 most of the time. #3 with a passenger. I only use the #1 setting, which is soft, on long trips with flat roads and no baggage.
2fas4u is offline
post #8 of 9 (permalink) Old 06-11-2007, 09:44 AM Thread Starter
Thanks Everybody! I absolutly LOVE this place!
post #9 of 9 (permalink) Old 06-11-2007, 06:15 PM
Rubline's Avatar
If you have a small portable compressor, you can set the air pressure knob on the compressor for 25 lbs. When you fill the shocks, the max pressure you will get is 25 lbs, thats what i did
Rubline is offline
