just a thought. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 06-06-2007, 12:48 AM Thread Starter
just a thought.
If we took off the "ears" and rep[laced them with k&n style filters, leaving the airbox, would we need to rejet the carb still?
tanz1983 is offline
post #2 of 12 (permalink) Old 06-06-2007, 02:46 AM
I've ran my bike before with out the chrome ear covers (with stock filters) and anytime I got above 4000rpms, the bike would start missing and didn't have any of that familiar Vulcan get-up-n-go.
Replaced the covers and all was fine.
So, IMO, I'd think ya would need to rejet.
post #3 of 12 (permalink) Old 06-06-2007, 03:29 AM
I agree with hyper. You will defeniatly have to re jet if you go to K&N filters. The increased air flow will cause your fuel to air mixture to become very lean.
piromedicx is offline
post #4 of 12 (permalink) Old 06-06-2007, 10:32 AM
Search Goddess
Dianna's Avatar
If you are just replacing the type of filters in the ears, you will not have to rejet, but you might want to adjust the air mix screws a bit.
If you are removing the ears and going with the pods at the carbs, you will.
An "ear shave" involves also removing the air surge tank located underneath the gas tank and adding the coasters
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #5 of 12 (permalink) Old 06-06-2007, 12:28 PM
I stand correct. Thanks Dianna. After I posted that post I was sitting in the place I do most of my thinking (the little room in the house with a sink toilet) and came to the same conclusion. I did a shave and removed the air box. I put everything back together and tried Roxie out. I kept increasing main and pilot jet sizes until I found a combo that worked. Not much fun and got kinda pricey, but, she runs excellent now (apart from the fact that she is in a million pieces due to a stator change and repaint.
post #6 of 12 (permalink) Old 06-06-2007, 01:37 PM Thread Starter
I'm in that same boat right now. I just want to get all things done why my bike is apart
tanz1983 is offline
post #7 of 12 (permalink) Old 06-06-2007, 01:56 PM
Not wanting to cause too much confusion.... I it took it as you wanted to remove the air filter housings (ears), leaving the air surge tank and have K&N type filters mounted where the air filter housings were.
Is this what you had in mind? Kind of a 'partial' ear shave?
post #8 of 12 (permalink) Old 06-06-2007, 02:55 PM Thread Starter
yes. I would leave the air box and just remove the outer ear cases.
tanz1983 is offline
post #9 of 12 (permalink) Old 06-06-2007, 04:55 PM
I don't think you will need to re-jet. Try it and see what happens. After all we only live once.
post #10 of 12 (permalink) Old 06-06-2007, 05:24 PM
fergy's Avatar
I believe what you will find is that the ears, or chromed covers that we call ears, restrict the airflow enough to match the jets we have in the carbs, stock. If you remove the covers and only have the K&N filters, or any other filters for that matter, I believe the uncovered filters will increase the airflow, causing what Hyper mentioned above, a lean condition. It wouldn't take much to throw things off. Seems like that is exactly what he did and found that it ran like crap over a certain rpm range.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
