Oil change - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 11-06-2013, 02:18 PM Thread Starter
Oil change
What torque should i use when i put the oil plug back?
CSS13 is offline
post #2 of 15 (permalink) Old 11-06-2013, 02:21 PM
Dr. Vulcanstein
jadabull's Avatar
Idk, I never go by foot pounds. I have a torque wrench but don't use it on this application, I just go a 1/4 turn past snug. Never had a problem.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #3 of 15 (permalink) Old 11-06-2013, 02:44 PM
davidfite1978's Avatar
Manual says 13ft lbs
\m/ Jaymz \m/
SOLD! 1999 Vulcan 750 | Pics (bought 3/29/2013 with 5657 miles)
Upgrades: MF/AGM Battery|Kaw F&S Luggage Rack|Kaw F&S Windshield|NGK Iridium plugs DPR7E1X-9|Kaw F&S Saddlebag Supports & Turn Signal Relocators|River Road saddlebags
Fixes: Repainted battery cage|Replaced bent clutch lever|Replaced left headlight bracket|Splines lubed and new tires @ 6,000mi.|Sold @ 6320 miles on 10/28/2013
davidfite1978 is offline
post #4 of 15 (permalink) Old 11-06-2013, 02:47 PM
post #5 of 15 (permalink) Old 11-06-2013, 03:14 PM
I just tighten it by feel. It requires so little torque that it would be hard to measure without a really accurate torque wrench. I always put a piece of blue paper/cloth shop towel between the wrench and the plug. Makes the wrench fit tighter, and protects the plug from wrench marks.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 15 (permalink) Old 11-06-2013, 03:18 PM
Ditto and it will be fine. Never once have I had an oil douche.
post #7 of 15 (permalink) Old 11-06-2013, 03:36 PM
^ X6! Hand tighten...
LibertyPilot is offline
post #8 of 15 (permalink) Old 11-06-2013, 04:47 PM
hand tighten and "feel" for the oring compression.........then stop!
if you overtighten the side drain you will crack the cast piece.
If you don't feel the rubber compressing and feel grinding....change the oring!
They can be had at any decent hardware store. I replaced the stock one with a slightly thicker o-ring and hand tight works fine.
post #9 of 15 (permalink) Old 11-06-2013, 04:54 PM
Wink
Yep, just snug, don't want to strip it.
Just snug applies to brake bleeders too, tell everyone, please.
post #10 of 15 (permalink) Old 11-06-2013, 08:27 PM
Just to be clear, do you mean the plug on the bottom of the engine or the one on the side with the screen and spring inside.
