VN750 gas mileage - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 26 (permalink) Old 05-18-2007, 09:16 PM
I get about 50mpg.
vulcan bob is offline
post #12 of 26 (permalink) Old 05-19-2007, 10:22 AM
Scratches in the dirt ...
GrayFox's Avatar
My last tank was 48 mpg. I've gotten as myuch as 56 and as little as 46. Stock pipes and air filters small shield and soft saddle bags. It really depends on how I ride. I'm usually fairly 'sedate' but I do occasionally crank her up and that's wehn I get the 46 to 48 mpg.
GrayFox ~v~ 16511
"Guthrun" 2002 VN750 bought in 04 with 1100 mi.
9000 miles as of Oct 08
Kawasaki F&S: engine guard, turn signal relocation kit, extended passenger backrest, saddlebag supports, V-Force shield.
W&M saddlebags, Beavisí voltmeter,
Gremlin bell, Chrome coolant cover, Chrome radiator frame, Fringe, Westco MF-AGM battery, Iridium plugs.
Photos at:
http://smg.photobucket.com/albums/v3...fox13/Guthrun/
Sub folders: radiator frame install, voltmeter install>
GrayFox is offline
post #13 of 26 (permalink) Old 05-22-2007, 09:13 AM
Man, I must be a speed freak or I am way out of tune...I get 35-38 if I am lucky. I was getting worse until I leaned the carbs.
My ride to work is 12 miles each way 9 miles on the highway, I do 65-70 on the highway traffic moves too fast to do 55.
What is the best thing for mileage highway or back roads? And my back roads have lots of stop lights and intersections.
PhilipLawlor is offline
post #14 of 26 (permalink) Old 05-22-2007, 09:33 AM
Unhappy
This last weekend I drove about 280 miles and averaged around 40 mpg. This seems low compared to some of the numbers that you guys are posting. I have stock everything and ride at mostly 60 - 65 mph on flat KS surfaces. I also have a medium size shield like a v-force or something similar. I am using Mobil 1 15w-50 in my case and mid grade 89 octane gas. Anyone have an idea to try?
PlainsRider is offline
post #15 of 26 (permalink) Old 05-22-2007, 09:58 AM
Tcat1000's Avatar
Hi Guys.........I have a 2006, iridium plugs, Nat. Cycle Street shield EX, Mobile one MX4T 10-40 motorcycle syn oil, Marbled, carbs set at 3 1/4 & 3 3/4 out, & get from 51 mpg to 61 mpg. The 61 was on a all day scenic drive at 30 to 55 MPH. The 51 + is everyday driving.
Last three tanks......51+....53+.....60.87 to be exact.........
BUT----------If you are a throttle jockey........hard accels...........freeway or any speed above 65 to God knows what................This is where your MPG's are going! (unless you have carb problems( Also, drop back to 87 octane & you will get better combustion & cleaner running. You guys that are running higher than 87 octane are just wasting your loot & hurting MPG & performance. 89 0r 92 octane slows the burn rate down & actually retards your timing through the higher octane fuel. If you take your plugs out, I would bet that they are blacker than a Raccoon's hiney! (Poor combustion & retarded timing).
I know what I am talking about, so don't argue!!!!!!
Also.....No flaming as I have locked out all flames on my puter.....
2006 VN750
Splines lubed With TSMOLY 70
R&R Relocated
Marbled (Cat's eyes no less)
Digital Volt, Amp, Temp gauge (Kisan)
Pipes Drilled
Carb Adj. at 3 3/4
Polaris AGM Battery (190 CCA)
Kaw rear rack
Kaw front engine guard
National Cycle Street Shield EX W/S
Mobile 1 MX4T 10W40 oil (Now labled 4T Racing)
Purolator PL14610 oil filter (Painted)
Iridium Spark Plugs
Pulsating Brake Light (Kisan)
My Motto: Don't get mad, just get even. Trust me, I will get even!
Tcat1000 is offline
post #16 of 26 (permalink) Old 05-22-2007, 10:30 AM
fergy's Avatar
I got 55 mpg once on a stretch of road in the hill country where I might have reached 55 a couple times but stayed in the 34-45 mph range, so I can say it's possible, even with a 265 lb redneck on it. I probably average around 60 mph on my daily driving and have been getting around 45 average.
I'll bet, just guessing, ... you weigh less than 265 Tcat???
My 02 has iridiums, marbled, etc... too. Just for the record.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #17 of 26 (permalink) Old 05-22-2007, 11:00 AM
Tcat1000's Avatar
Usually my weight, age and IQ are nobody's business..........BUT, in this case for the record I tip the scales at 189 soaking wet.......
2006 VN750
R&R Relocated
Pipes Drilled
Carb Adj. at 3 3/4
Kaw rear rack
Iridium Spark Plugs
Tcat1000 is offline
post #18 of 26 (permalink) Old 05-22-2007, 11:11 AM
Tcat1000's Avatar
AND......further more......you Southern Rednecks probably do a lot more stopping than us Michiganders do!
(Taverns, BBQ joints ETC.) Hurts mileage ya know........
Wife & I were driving our Goldwing pulling a trailer headed to Abilene, & damn near hit a MOO COW crossing the road, so TX is not my favorite State among several other reasons!
We only have Bear, Deer & wild Turkeys to look out for. (Well, stupid four wheelers too)
2006 VN750
R&R Relocated
Pipes Drilled
Carb Adj. at 3 3/4
Kaw rear rack
Iridium Spark Plugs
Tcat1000 is offline
post #19 of 26 (permalink) Old 05-22-2007, 12:30 PM
Gnarly Jokester
norsseman's Avatar
Location: Southwest of Ruby Ridge, Geiger Heights, Washington, USA.
I ride a motorcycle because I like the roar of the pipes, the feel of fast acceleration, the feeling of balance, so my mileage is poor for a mc, about 25-35, but on the highway I get around 45 mpg loaded down.
"When the sun's comin' up,
I got cakes on the griddle.
Life ain't nothin' but a funny funny riddle,
Thank God I'm a Country Boy!"
norsseman is offline
post #20 of 26 (permalink) Old 05-22-2007, 05:14 PM
jeez, Tcat.
I can't see why you would ever get flamed...
