Rhythmic clunking sound - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 05-10-2007, 12:58 PM Thread Starter
Joem's Avatar
I have a mystery noise for the wrenchers here to diagnose. When I start the bike I hear a clunking sound very similar to the sound of a gear change. It is just a clunk..clunk..clunk about 3 times a second, and it does not increase in frequency when you roll on the throttle. It is not very loud. I can hear it when I'm riding, but only when I roll off the throttle. It seems to decrease as the bike warms up. It is not really a brand new noise. I've been hearing it for some time now, maybe since I've owned it. Is this a normal noise, or something I should get checked out.
Joe
Joem is offline
post #2 of 13 (permalink) Old 05-10-2007, 01:24 PM
HAWK
Ccspinner's Avatar
MIght be the ACCT, cam noise is loud.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 13 (permalink) Old 05-10-2007, 03:15 PM
Sky Rider's Avatar
If it does not increase when you roll on the throttle, it is probably not engine related. Had it increased freq with an RPS increase, then I would suspect the ACCTs. Can you localize where the noise is coming from?
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 13 (permalink) Old 05-11-2007, 11:22 AM Thread Starter
Joem's Avatar
That was my thought too. Other than from the engine area I can't really narrow it down. I am doing some other work on the bike this weekend and I will listen around it and try to tell more specifically where it ias the loudest. Is there something (oil pump, water pump, etc) that operates at a steady rate no matter how fast the engine is running? This is not anything that is affecting it's performance (so far). My bike is a 95, but the mileage is low. It had 2800 on it when I bought it last May. It is right around 10000 now.
Joem is offline
post #5 of 13 (permalink) Old 05-11-2007, 01:42 PM
fergy's Avatar
The fact that it doesn't increase speed with the engine speed has really got me baffled. The only electric motor I can think of is the fan motor, other than the starter. Drawing blanks here.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #6 of 13 (permalink) Old 05-11-2007, 02:57 PM
You might be able to isolate the sound with a mechanics stetascope. About $10 at you parts store. I used to use a piece of broom handle. Place your ear on one end of the wood and move the other end over the engine. The sound will usually be louder close to its origin. Try several different angles to find the center location for the sound. You must be sure of solid contact between the wood and you engine for correct sound conduction. I agree that it is not an internal engine part if the sound does not increase in frequency with the engine RPM's. Fan motor is one possibility also check out electricl relays.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #7 of 13 (permalink) Old 05-11-2007, 03:02 PM
Search Goddess
Dianna's Avatar
You mentioned that it seems to decrease as the bike warms up.. which makes me wonder if it's the coffee grinder sound related to the clutch.
What type of oil are you using?
A quick test for you.. when you start up the bike and hear the sound does it go away if you squeeze the clutch lever several times?
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #8 of 13 (permalink) Old 05-11-2007, 03:48 PM Thread Starter
Joem's Avatar
I use Shell Rotella T 15W-40. I will try what you suggest with the clutch. The little clunk when you shift is the closest thing to the sound I hear, so it makes sense that it may be a clutch thing. I don't think I would describe as a coffee grinder noise though. It is much more like if you lightly tap the side of your thumb on your desk at the rate of 3 or 4 taps per second.
Joem is offline
post #9 of 13 (permalink) Old 05-20-2007, 10:11 PM
Hi Joem,
I have the same problem..! I'm riding a 1995 vn750, great bike, but this problem started a few months ago, after using a synthetic oil instead of the SE, SF or SG API service type oil they specify. These bikes have an oil immersed clutch.
I tried tightening the timing chains, but these are supoposed to adjust automatically. I have also listened with the screwdriver and the scope, but very difficult to detect.
I think I'll take it to my mechanic soon, maybe tomorrow, and see what he says, but I suspect either clutch related or timing chain related....
I will get back to you soon...
carlos is offline
post #10 of 13 (permalink) Old 05-21-2007, 12:06 AM
"Light tap of your thumb on the side of your desk"......You might want to check for a simple exhaust leak. That is exactly how I would describe the sound mine made when the Exhaust nuts came loose.
GoUglyEarly is offline
