1999 vulcan emergency - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 35 (permalink) Old 05-07-2007, 02:32 PM Thread Starter
Hi everyone. I have a 99 Vulcan 750 and I have been having a problem with it. When the Engine is cold the bike starts up just fine. After I go for a ride and shut off the engine the engine wont start until it is cold. Does anyone know how I can fix this. The weather is getting real nice and I am with out my bike
Thanks
stinky skunk is offline
post #2 of 35 (permalink) Old 05-07-2007, 03:05 PM
fergy's Avatar
More than likely, you have a weak battery causing the problem. Everyone suggests to swap out your wet cell battery for a maintenance free, sealed battery. Higher cranking amps and the fact that you don't need to pull your seat to check the liquid levels, make this a win/win. The starter on our bikes takes a massive amount of the amps to turn the engine and not enough is left to give good spark when the engine is warm. In my case, I already had an MF battery in mine, but still had the hot start problem. Not knowing how old my battery was, I chose to move my regulator/rectifier to a cooler location, on the left side of the bike, next to the passenger foot peg. I also did a coil wire/relay mod at the same time, firing the coils directly from the battery with higher gauge wire. This solved my hot starting problem, period. I still have the same battery a year later and my charging system still performs excellent. You need the MF battery if you don't already have one, so I'd start there.
Remember, no throttle when you first touch the starter when hot, just blip it after it starts turning and it should start. If you give it too much throttle, you'll probably get a massive backfire, when unburnt gas hits the exhaust and some fresh air!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 35 (permalink) Old 05-07-2007, 03:21 PM Thread Starter
Where can i get a Maintance Free Battery
post #4 of 35 (permalink) Old 05-07-2007, 05:00 PM
Crobins365's Avatar
I got mine at Sears, and I think it was about $90. Just make sure you get the specs from here (nmber and stuff), and you should be able to walk in and walk out in a matter of minutes. Good luck!
C
Crobins365 is offline
post #5 of 35 (permalink) Old 05-07-2007, 05:03 PM
93VN750's Avatar
You can also try batteriesplus.com on line, and see if they have a local store. Got mine from them locally for $ 50 and change.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #6 of 35 (permalink) Old 05-07-2007, 05:03 PM
Stranger Than Fiction
cmanningjr's Avatar
Send a message via MSN to cmanningjr
I got mine last week at Batteries Plus. $64 and some change.....
'92 Vn750
cmanningjr is offline
post #7 of 35 (permalink) Old 05-07-2007, 05:42 PM
BigT's Avatar
I bought mine from Advanced Auto Parts. It already had the acid installed and was fully charged. The posts are backwards from most batterys though, so some creative wiring is necessary.
One positive about that battery is that the posts can be side mount and top mount. I have my leads attached to the side posts and the battery tender to the top. It works fine for me.
I smile 'cause I don't know what the h*ll is going on.
BigT is offline
post #8 of 35 (permalink) Old 05-07-2007, 05:48 PM
93VN750's Avatar
That sounds a lot like a wet acid type, you sure it's a MF AGM type? Makes a HUGE difference. Never seen them at Advanced.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #9 of 35 (permalink) Old 05-07-2007, 11:28 PM
I just checked their store locator out, and it turns out there's a store less than 15 miles from me.
I know where I'm going this weekend. Thanks Jon.
post #10 of 35 (permalink) Old 05-07-2007, 11:54 PM
HAWK
Ccspinner's Avatar
Stinky what part of Wisconsin are you from?
I live in Illinois by the border and Lake Michigan.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
