Chirping.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 05-04-2007, 11:05 PM Thread Starter
Benjammin'
BSkaggs513's Avatar
Chirping....
Has anyone figured out what causes our bikes to make a chirping sound at around 3k on the tachometer? I have seen posts in here before, but I don't think I ever heard why it does it.
Thanks!
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #2 of 14 (permalink) Old 05-05-2007, 12:36 AM
HAWK
Ccspinner's Avatar
Little birdy flying close
No really I don't have a noise like that, do you have any mods on the bike?
Windsheld or anyting that can create a wind noise?
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 14 (permalink) Old 05-05-2007, 01:46 AM
I think some of the (to me more like whistling) sounds I hear is air going through (what Ron Ayers refers to as) the gas tank covers.
post #4 of 14 (permalink) Old 05-05-2007, 09:25 AM
Rubline's Avatar
My 06 makes the same noise. My old Z1 did the same thing. I'm guessing that it has something to do with harmonics. When the motor spins at a certain rpm it produces that sound. No worries though.
Rubline is offline
post #5 of 14 (permalink) Old 05-05-2007, 12:05 PM Thread Starter
Benjammin'
BSkaggs513's Avatar
No windshield, no modifications. The bike has always done that since I bought it (used). It is odd in that the ONLY time I hear it is when cruising at 3000 RPM. No matter what gear, no matter what speed. At first, I thought it may be an exhaust leak at the header. Changed crush gaskets- no difference. You may be right- it is something in the design of the engine.
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
post #6 of 14 (permalink) Old 05-05-2007, 12:39 PM
Crobins365's Avatar
You might check the tachometer, too, and just make everything's okay there. Usually that kind of chirping can get worse at higher rpms, but there may be a glitch that's causing you to hear it at 3K.
C
Last edited by Crobins365; 05-05-2007 at 12:41 PM. Reason: meant tach, said speedo
Crobins365 is offline
post #7 of 14 (permalink) Old 05-05-2007, 09:11 PM
sunpa's Avatar
My '04 makes a similar chirping sound at about 3K RPM. I thought it was just my bike. The sound seems to be related engine temperature. It doesn't make the sound until the temp guage moves above the lower white line into the normal range. On cold days (~40 degrees) I could ride 10 miles with no chirping, then it would start when the engine temp finally climbed out of the "cold zone", but only at ~ 3K RPM. My thought is that it is something in the thermostat vibrating as it opens. I haven't worried too much about it since the temp guage never goes above the midpoint. I do have some concern that, if it is the thermostat making the noise, it may be an indication of a future failure.
- Safety First
Paul
'04 VN750
'75 CB360T
'08 Concours 14
sunpa is offline
post #8 of 14 (permalink) Old 05-05-2007, 10:33 PM
HAWK
Ccspinner's Avatar
Could be the heat sheld on the exhaust. Mine made a chirping type noise untill I shifted them, I found it by riding and putting my foot on the sheld and it went away.
Dont put your foot on the pipe just the heat sheld.
Chad Falstad "Hawk"
Vroc #17649
post #9 of 14 (permalink) Old 05-05-2007, 11:48 PM Thread Starter
Benjammin'
BSkaggs513's Avatar
Come to think of it, the noise does seem to be audible when the bike heats up. Riding in cooler temps and when the bike has not warmed up all the way I have not heard the 'birdie'.
I have been all over my bike (while sitting still) trying to find potential vibration places. I moved cables and wrapped others with rubber hoses with no luck. I will try to hold my foot on the heat shields to see if any luck there. Thanks for the suggestion!
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
post #10 of 14 (permalink) Old 05-06-2007, 03:01 PM
slim's Avatar
mine did the same thing when i first got it. I found it to be the heat shield on left side. Since i have changed exhaust no more chirping.
slim is offline
