Kickstand problem... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 04-23-2007, 11:31 PM Thread Starter
TheBoy's Avatar
Send a message via AIM to TheBoy
I lowerd my VN750 with a Progressive 412 series and i also had a lowering kit installed in the front forks which dropped it 2 inches . I love how its looks and how it rides. But i have a huge problem. Since i lowered the bike, it stands straight up with the kickstand down. So what im trying to find out is how to correct this. I was thinking about cutting a piece out and re-welding it, or just heating it up and bending it. What did you guys do that lowered you bikes.
TheBoy is offline
post #2 of 7 (permalink) Old 04-23-2007, 11:34 PM
HAWK
Ccspinner's Avatar
Cutting and welding is not a bad Idea.
You can just move the foot up and not cut it in the middle.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 7 (permalink) Old 04-24-2007, 12:09 AM
Mohycle
mohycle's Avatar
Also, if you haven't already figured this out, the centerstand is now lower too. Very hard to deploy if you are a weakling like me. Just back your rear tire onto a 1" or 2" board, then proceed as normal.
Mo
mohycle is offline
post #4 of 7 (permalink) Old 04-24-2007, 06:19 AM
The Cut & Weld like Chad describes sounds like the best bet.
post #5 of 7 (permalink) Old 04-24-2007, 10:09 AM
"ya can't live forever"
artman's Avatar
Cut and weld.
artman is offline
post #6 of 7 (permalink) Old 04-24-2007, 11:29 AM
BMan23777's Avatar
On mine I groung down the bottom of the foot on the kick stand,tapered it more.and then on the front side of the stand I ground down the area were it comes in contact with the stop on the frame mount.Worked great.I have seen others that have cut and welded theres,The usually take out 3/4 of an inch when the do it.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #7 of 7 (permalink) Old 04-24-2007, 07:08 PM Thread Starter
TheBoy's Avatar
Thanks guys, i think i will try and get it welded
TheBoy is offline
