Pics of my rebuild - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 04-01-2007, 05:54 PM Thread Starter
Stranger Than Fiction
cmanningjr's Avatar
Send a message via MSN to cmanningjr
Pics of my rebuild
I got the yard work caught up this weekend. So I finally got started on my bike. Here's the story, bought a 2002 Vulcan last year that was wrecked. (Very Cheap) Bent forks, then later found out bent frame. So, buying bits here and there over the winter, I ended up with a nice frame. Anyhoo, got the engine swapped over today. One man job, 2.5 hours.
Name:	Engine Out 0401062.JPG
ID:	304   Click image for larger version
Name:	New Frame 0401062.JPG
ID:	305   Click image for larger version
Name:	In Frame 0401062.JPG
ID:	306   Click image for larger version
Name:	On Lift 0401062.JPG
'92 Vn750
cmanningjr is offline
post #2 of 16 (permalink) Old 04-01-2007, 06:09 PM
Crobins365's Avatar
Nice-looking engine! Wow! And only 2.5 hours?! That must be a record.
C
Crobins365 is offline
post #3 of 16 (permalink) Old 04-01-2007, 06:21 PM Thread Starter
cmanningjr's Avatar
Added More Pics,(Had to resize)
I found out that it's easier to install the engine with it sitting on the floor. You can slide the frame over the top of it. Then I used a hoist to put it on the lift.
I didn't find any critters Cindy, but if I do, I'll send them your way. ;-)
'92 Vn750
post #4 of 16 (permalink) Old 04-01-2007, 07:57 PM
Crobins365's Avatar
He he - I'm all about insecticide these days. Looks like you have the swingarm covers intact on the new frame as well? Good get!!
C
post #5 of 16 (permalink) Old 04-01-2007, 08:06 PM
Just a few more nuts & bolts to go !! LOL
Hope it all goes as well as the engine install did
post #6 of 16 (permalink) Old 04-09-2007, 11:25 AM Thread Starter
cmanningjr's Avatar
No pics this weekend. It was too cold to do much. 27' Saturday morning. Burrrr... So later in the afternoon when it hit 45'......
Installed front end
Front Wheel
Greased Splines
Installed Final Drive
Installed Shocks
Then it started to get cold again so I called it a day.
Sunday/Warmer around noon it was 45' so to the shed I went.
Installed rear wheel
Rear Brakes
Wiring harness
Battery Box
Foot Pegs
Handlebars
Levers
Radiator
Headlight
Rear Fender
Started Making Electrical Connections and Deciding where to mount the R/R
Then made sure I had locktite on everything and torqued all the bolts as per the service manual.....
It's a roller.........Hope to crank her next weekend, but we'll see.......
'92 Vn750
post #7 of 16 (permalink) Old 04-09-2007, 12:32 PM
fergy's Avatar
Progress!! It will feel good to crank her up!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #8 of 16 (permalink) Old 04-14-2007, 10:29 PM Thread Starter
cmanningjr's Avatar
Ok, I need to retitle this "Build or Bust"
Finished all the wiring today, Installed exhaust, Put in battery...Try to crank, Turns over but will not catch. I don't think I'm getting fuel to the carbs. I checked the lines coming from the petcock and they were almost dry. (Yes, Gas in tank, and Petcock is on) I checked for spark and I'm good there. Thunderstorm came up and I came back in the house. In the morning I will check to see if I have gas in the bowls. Possible bad petcock, no vacuum? Any more suggestions??? Ideas??? Prayers???
'92 Vn750
post #9 of 16 (permalink) Old 04-14-2007, 10:58 PM
85 VN 700
curtis97322's Avatar
quick way to test the petcock - hook up an appropriately sized syringe (or mityvac or...) to the petcock, see if fuel flows. If fuel flows, you know the problem lies elsewhere... if not, it might be petcock rebuild (or at least clean) time.
Good luck!
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #10 of 16 (permalink) Old 04-14-2007, 11:34 PM
Uber Member
keep in mind the engine must crank to open the petcock so fuel can flow into carbs... crank it for a few seconds to get a vacume.... and then let it sit for 10 mins, and try again, wait if needed....
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
