Spare parts on rides - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 02-06-2007, 10:34 AM Thread Starter
Drive less, ride more...
theauhawk's Avatar
What VN750 spare parts would you recommend be taken on a ride of any real length, that can be replaced without the need for a shop? Spare fuses? A spark plug, maybe?
To word the question another way--what VN750 parts are generally most likely to fail (besides the stator, r/r--or perhaps a flat tire) that can be reasonably repaired in the field?
The above of course assumes that the bike is otherwise maintained properly....
theauhawk is offline
post #2 of 15 (permalink) Old 02-06-2007, 11:58 AM
fergy's Avatar
On trips, I take a spare headlight bulb, a bottle of seafoam (never know what kind of gas you'll get stuck with) my compressor (tiny one from Walmart, have my tender pigtail on my battery where I can plug a cig lighter pigtail to it for using the compressor) a tire plug kit, some tools, some rags and a can of Honda Pro cleaner, extra fuses of course, but no spare parts. Spark plugs might be a good idea, but I have new iridium plugs so I don't imagine I need spares, or don't plan to need spares anyway.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 15 (permalink) Old 02-06-2007, 12:10 PM Thread Starter
theauhawk's Avatar
I might add to the above list...a smaller set of jumper cables.
BTW: what sizes/capacities of fuses (or what range, if I buy a pack) do you recommend?....
post #4 of 15 (permalink) Old 02-06-2007, 12:18 PM
fergy's Avatar
Off the top of my head, I don't recall the sizes. But I know they are duplicates of the ones on the bike. I carry a couple spares of each of the ones in the fuse box, along with the spares that are in there. I think it is two sizes, maybe a 10 and a 30, but I'm not sure.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #5 of 15 (permalink) Old 02-06-2007, 12:52 PM Thread Starter
theauhawk's Avatar
I gather that 90% of the time, when a bike leaves someone stranded--the problem is actually an electrical issue.
So does anyone else have any other suggestions on this topic?.....
post #6 of 15 (permalink) Old 02-06-2007, 01:04 PM
HAWK
Ccspinner's Avatar
If you can get a spair R/R. That would not be a bad Idea.
You could relocate one and leave one in the stock location so it is always there.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #7 of 15 (permalink) Old 02-06-2007, 01:12 PM
fergy's Avatar
Volt meter mounted on the bike somewhere is a good idea. Of course that's for all time not just trips.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #8 of 15 (permalink) Old 02-06-2007, 03:18 PM Thread Starter
theauhawk's Avatar
Especially in light of more chronic electrical problems, your point Fergy about the voltmeter is a good one.
Where are the best places to mount one of those on the bike? What are some of the more recommended voltmeters for this use?
post #9 of 15 (permalink) Old 02-06-2007, 03:56 PM
darrelc5's Avatar
Now THAT is a good idea!
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #10 of 15 (permalink) Old 02-06-2007, 04:07 PM
Uber Member
i also recomend a spare of each hand lever. it is common that when the bike is dropped, its less then 15mph. this leaves little damage to the bike and in most cases rideable, but sometimes the hand levers will bend or break. this way you can at least make it to the nearest shop if you need further repairs without a tow.
also a spare H4 headlight, hard to find out in rual areas, a small set of tools, a decent LED based flashlight (b/c of the run time) and depending on the spacing of gas stations, there are some aluminum gas bottles too...
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
