Lost key - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 01-03-2007, 04:41 PM Thread Starter
Lost key
I have a 2003 vulcan 750, my daughter lost my only key to the bike.Can a Kawasaki dealer make a new key with the vin number,? need some advice,other than dont let your daughter have your bike key.thanks
gatman83 is offline
post #2 of 6 (permalink) Old 01-03-2007, 06:55 PM
Mushu's Avatar
Send a message via MSN to Mushu
That's unlikely to be the case, what you may have to do it to replace the pins on the lock cylinder and get the new key for it. Your local Kawasaki dealer should be able to get this done... do ask around... they could let you know what they can do...
93 VN750
R/R Relocation to the front
Pirelli MT66 Tires soon to be mounted (only after 14 years...)
Mushu is offline
post #3 of 6 (permalink) Old 01-03-2007, 07:25 PM
a good lock smith should be able to make you a new one.
wwmkwood is offline
post #4 of 6 (permalink) Old 01-04-2007, 04:42 AM
There was an ignition w/keys on ebay. Not sure if it's still going on though.
But like Wwmkwood said, a locksmith should be able to make a key, providing you remove the ignition switch. You may be able to use the tool box lock instead, but I'm not positive on that.
post #5 of 6 (permalink) Old 01-04-2007, 08:57 AM
Search Goddess
Dianna's Avatar
The tool box, helmet locks, gas cap and ignition all use the same key but at different levels. The ignition key is the one that uses the entire key length I believe. But a good lock smith should be able to make one. Get a spare done while you are at it!
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #6 of 6 (permalink) Old 01-04-2007, 11:31 AM
Uber Member
or 2!!!! give one to your significant other if u have one. that way they can bail u out if u lose it again!
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
