Help.....Side cover bolt - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 01-01-2007, 10:16 AM Thread Starter
Tcat1000's Avatar
Does anybody have any ideas for getting that *@^%#*#% side cover bolt off my 2006 750 bike? It's the cross or T type bolt holding the side cover on & the S.O.B. won't budge! I tried a very large flat screwdriver with a crecent wrench on it & it still won't come off. I am afraid of breaking it off if I get any more aggressive.
Thanks Tcat
2006 VN750
Splines lubed With TSMOLY 70
R&R Relocated
Marbled (Cat's eyes no less)
Digital Volt, Amp, Temp gauge (Kisan)
Pipes Drilled
Carb Adj. at 3 3/4
Polaris AGM Battery (190 CCA)
Kaw rear rack
Kaw front engine guard
National Cycle Street Shield EX W/S
Mobile 1 MX4T 10W40 oil (Now labled 4T Racing)
Purolator PL14610 oil filter (Painted)
Iridium Spark Plugs
Pulsating Brake Light (Kisan)
My Motto: Don't get mad, just get even. Trust me, I will get even!
Tcat1000 is offline
post #2 of 5 (permalink) Old 01-01-2007, 10:58 AM
Crobins365's Avatar
Try a good sploot of Liquid Wrench or PB Blaster, and then use your ignition key...oddly, the key is made to fit that slot. But the LW or PB should help a lot.
C
Crobins365 is offline
post #3 of 5 (permalink) Old 01-01-2007, 01:15 PM
If it's that tight, I don't know if I'd try using the key just yet.
But definatley give it a shot of some penetrating oil. If ya have an impact screwdriver (the kind ya wack with a hammer), that should bust it loose.
My guess is the guy who tightened them bolts on the assembly line was ticked off that the spline lube guy got to sleep on the job, so he really cranked 'em down! LOL
post #4 of 5 (permalink) Old 01-01-2007, 05:03 PM
Just don't miss with the hammer, side covers will break.
wwmkwood is offline
post #5 of 5 (permalink) Old 01-02-2007, 05:58 PM
Rubline's Avatar
I had the same problem with my 06. Couldnt get it off to save my life. The next time I was in the neighbor hood, I had the dealer remove it. Then I put neversieze on the threads.
Rubline is offline
