Clymer cable lube instructions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 12-21-2006, 12:17 PM Thread Starter
This weekend I decided to lube my throttle and choke cable on my '05. The last instruction for each in Clymers was to "remove the gas tank as instructed in chapter 7". Can anyone tell me why it might say that? I did not do that and everything seemed to work fine.
lbcole0915 is offline
post #2 of 10 (permalink) Old 12-21-2006, 12:23 PM
Uber Member
not a clue. i just took a really small funnel, and poured in several drops of clean motor oil. then let gravity and the normal use do the rest of the work.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 10 (permalink) Old 12-21-2006, 02:22 PM
Maybe they didn't think enough time and energy was spend on the cable lubing process itself and just want you to work a little harder ?! LOL
Honestly though, the only reason I can think of is, maybe to clean up any lube that seeped out the other end of the throttle cable.
Just a guess.
post #4 of 10 (permalink) Old 12-21-2006, 02:30 PM
if you follow the manuals you have to either remove the tank or pull the motor for everything lol
TrashLord is offline
post #5 of 10 (permalink) Old 12-21-2006, 07:04 PM
Now what
Ironman's Avatar
I'd check the air pressure in the tires more often but the engine pull is a killer
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #6 of 10 (permalink) Old 12-21-2006, 08:12 PM
Uber Member
you should see what my haynes has me do to fill my wiper fluid on my jeep.... never thought i would have to remove both axles :P
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #7 of 10 (permalink) Old 12-21-2006, 08:32 PM
Avid Rider
stevebtx12's Avatar
Send a message via Yahoo to stevebtx12
Graphite?
I used to use this graphite based oil for the cables on my dirt bikes. Anyone used any graphite based lube on the vulcan cables? Any pros or cons before I go for it? Thx.
Steve in TX
'06 VN1600 Classic
V&H Bigshots
F&S windshield/lowers
Mustang seat/driver backrest
OEM saddle bags/Easy brackets
Phatt II risers
Cobra fatty highway bar/Kury Dually highway pegs
Cobra sissy bar/luggage rack
Iso Flame grips/throttle boss
VROC #22372
"Some days you're the windshield, some days you're the bug." (me)
stevebtx12 is offline
post #8 of 10 (permalink) Old 12-22-2006, 01:59 AM
Uber Member
I personally havent used it, but keep in mind our bikes arent subjected to the same extremes. so unless you already have it, it may be a lil overkill. Your only trying to prevent rust from forming in the cables, so any type of lube should work well.
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #9 of 10 (permalink) Old 12-22-2006, 04:11 AM
I usually just use WD40 or something similar. Displaces moisture, and somewhat keeps it lubed. Yet doesn't build up as it dries out.
If ya can find teflon lined cables (I don't even know if anyone has 'em for the Vulcan???) ya shouldn't need to worry about lube at all.
post #10 of 10 (permalink) Old 12-22-2006, 07:30 AM
Avid Rider
stevebtx12's Avatar
Yeah, I still have the graphite based stuff leftover, and it is some extremely slick sh*%, but I thought I check in here before I used it. Thx
Steve in TX
'06 VN1600 Classic
V&H Bigshots
Phatt II risers
VROC #22372
